resister box question
Old Sep 22, 2005 | 09:02 PM
sir2sol's Avatar
Default resister box question
when do i need a resister box for my injectors? i know that it has to do with be saturated or non saturated, but i can't remember which is which.
Old Sep 23, 2005 | 03:22 AM
jmcclell's Avatar
Default Re: resister box question (sir2sol)
You need a resistor box when using the "peak and hold" type of injectors.
To find out what type you are using, just measure the coil resistance of the injector.
2 ohm coil = peak and hold type
12 ohm coil = saturated type
Hope this helps
Old Sep 23, 2005 | 08:52 AM
drdisco69's Avatar
To answer this question based on your other posts, OBD1 injectors are saturated, and do not require a resistor box.
jetspeedz
Jul 27, 2009 07:14 PM
TehGhett0P1mp
Dec 15, 2008 12:33 AM
deucedeuceEK
Oct 30, 2007 04:35 PM
SFlCrx
Mar 21, 2007 05:48 PM
