negative camber
Old Sep 22, 2005 | 07:57 PM
lilhatch's Avatar
Default negative camber
I swaped a gsr motor in my 91 hatch which makes the front end lower and now both of my front wheels have a negative camber. do i need do buy 1) a whole new suspension 2) a camber kit or 3) is there another way to fix this problem. i dont have much cash right now but i need to fix this problem. i still have the stock suspension.
Old Sep 22, 2005 | 08:25 PM
Tyson's Avatar
Default Re: negative camber (lilhatch)
negative camber is not a problem.
if youre worried about tire wear, get your car aligned to set your toe correctly. bad toe in affects tire wear, not negative camber.
negative camber is good for handling.
Old Sep 23, 2005 | 01:00 AM
bc_ef8's Avatar
I agree with Tyson. Get an alignment.
I'm running -2.25 camber up front with my toe @ 0 and I have very very minimal camber wear
Old Sep 23, 2005 | 03:10 AM
jisu009's Avatar
Default Re: negative camber (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">negative camber is not a problem.
negative camber is good for handling.</TD></TR></TABLE>
Tyson speaks the truth
Modified by jisu009 at 4:21 AM 9/23/2005
Old Sep 23, 2005 | 07:12 AM
lilhatch's Avatar
Default Re: negative camber (jisu009)
thanks alot i just took it to get it aligned today.
Old Sep 23, 2005 | 10:42 AM
red_EF9Si's Avatar
umm, you're kidding right. although toe settings can cause severe tire wear, camber can do just as much damage...if not more. my car is lowered 3 1/4" which caused about 5 degrees of negative camber. my tire to road contact patch was about 4 inches at all times. what do you thing was happening to those 4 inches of tire? wearing the hell out of them thats what. bottom line..if you have severe negative camber, get a camber kit. although if its not more than say 2 degrees...dont worry about it, its good for handling.
Old Sep 23, 2005 | 11:02 AM
fireant's Avatar
Default Re: negative camber (red_EF9Si)
-2 degrees is not a problem with zero toe.
-5 degrees is absurd.
Old Sep 23, 2005 | 11:53 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilhatch &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot i just took it to get it aligned today.</TD></TR></TABLE>
im curious what your printout read. please share.
Old Sep 24, 2005 | 03:34 PM
lilhatch's Avatar
wellthe alignment helped with that camber. before it was at like -4 now its like -1.
Old Sep 24, 2005 | 06:40 PM
Tyson's Avatar
im not sure i understand that.
can you write out the numbers, verbatum.
noz
Suspension & Brakes
Feb 18, 2009 07:53 PM
blinger
Oct 18, 2007 06:36 AM
The Si
Suspension & Brakes
Feb 5, 2007 09:03 PM
$amGD3
Suspension & Brakes
11
Sep 5, 2005 05:16 PM
smikeL
Jan 7, 2005 11:13 PM
