89 prelude takes 4 or more times to start ???
Old Sep 22, 2005 | 06:22 PM
kriskonway's Avatar
Default 89 prelude takes 4 or more times to stay running
Hi,
My normally flawless prelude's check engine light came on a few weeks ago for an hour then went out. now this past week a weird situation keeps reoccuring.
when starting the car after sitting a while, it starts up right away but dies as fast as it starts. It's as though the ignition turns off as soon as it starts.
The car will only stay running after I restart the car on the third or fourth time.
Any ideas ?
btw.
89 prelude 276,000 kms totally stock. fuel inj
Old Sep 23, 2005 | 07:36 PM
kriskonway's Avatar
Default Re: 89 prelude takes 4 or more times to stay running (kriskonway)
so, I did this trick where if the car wants to die when it's cold, i hold the key forward as though im engaging the starter but not enough that it engages which in turn keeps the car running... then after a 10 - 20 seconds, i can let go of the key and it will stay running. if i let go too soon, it dies...
wtf...
Old Sep 23, 2005 | 07:52 PM
AndyD's Avatar
I wonder if the ignition switch is bad. That's all that I can think of based on your description.
Old Sep 25, 2005 | 04:20 AM
01_prelude's Avatar
how long does it take to start when turning it over? first check your battery voltage, cranking amps, and altinator. the battery may be low making the ignition over work it self.but a fuel problem sounds more like it
Have you had any fuel problems? check fuel pump or filter
Old Sep 25, 2005 | 09:39 AM
BigJ5's Avatar
Check the PGMFI relay, it's under the dash on the driver's side...
rovertnamrod
Honda Civic (2001 - 2005)
12
Jul 17, 2013 06:25 PM
H2BKid42
Oct 12, 2011 03:09 AM
SouthTexasRich
Jun 17, 2011 07:04 AM
silverboost
Dec 5, 2006 10:20 AM
br3ak3r84
Sep 30, 2006 11:23 AM
