h22 rebuilt 63 miles later motor seizes
So i just spent alot of money on this motor, and after i get it runnin its runnin perfect, i didnt have any problems at all, i did my valve adjustment to spec, hit it with a timing light, and had a wideband o2 reading 14.67. Im drivin down the street about 30mph 2nd gear 4200rpms and the motor seizes. I get the thing towed to my house take it apart and 2 valves broke, one is bent (all in cyl 3) the cylinder wall is fucked up, the combustion chamber is fucked up, and my piston is in hundreds of pieces in my oil pan, and the rod is still intact, pin and all, just bent. Any ideas as to what could have caused this, and if it could be the machine shops fault (they ported and polished, and assembled my head)? And my timing was all fine after i seized.
http://www.cardomain.com/ride/1474662
PICS^^^^
93 H22a1 with....
AEM cold air intake
full exhaust set up (no cat)
throttle body spacer
port and polish (5angle valve job)
Skunk2 valve springs
Skunk2 1mm oversized high compression valves
Skunk2 Titanium retainers
milled head
Crower stage 3 cams
Volution adjustable cam gears
MSD wires
Bosh 4 electrode plugs
XTD stage 3 clutch
XTD light weight flywheel
underdrivepulley
AEM powerpullies
DC short shifter
Power Slot slotted rotors
PLX wideband o2 sensor
Modified by 93h22a1vtec at 8:12 PM 9/26/2005
PICS^^^^
93 H22a1 with....
AEM cold air intake
milled head
Crower stage 3 cams
MSD wires
XTD stage 3 clutch
underdrivepulley
AEM powerpullies
DC short shifter
jdmlude_dude
Apr 30, 2006 06:54 AM
jdmlude_dude
Mar 17, 2006 03:44 AM
93h22a1vtec
34
Dec 12, 2005 03:56 AM
