is it bad when my car wont start???????????
Old Sep 22, 2005 | 05:55 PM
hamburgler's Avatar
Default is it bad when my car wont start???????????
ok heres my problem....i got in my car started right up...i drove to my friends starter right back up....but when i got to my dads right before work it wouldnt start...it made a sounds like a gear wouldnt go in.....so after i clutch start it twice and got back home after work.....i took it off and took it to orellys to replace it (lifetime thing).they said the starter was fine it was prob my flywheel has a chip in it somewhere.....didnt sound right to me.anyway i forgot to say that when i got home from work i turned it off and try to start it again....it made that bad grinding sound again but started up.....u guys have any clue on what it could be?????/
thanks,cory
Old Sep 23, 2005 | 03:57 PM
Sam92Teg's Avatar
Default Re: is it bad when my car wont start??????????? (carless87)
Make sure your starter mounting bolts are nice and tight. Might as well check your starter connections as well as your grounds also, good luck.
You can also pull the inspection plate from under the car and look at all the flywheel teeth for damage.
JPerkMr954
Jun 9, 2013 08:51 PM
dominate9
Jan 16, 2009 04:32 AM
RiCE On IcE 2
Dec 15, 2005 10:38 AM
projectPSI
Mar 18, 2005 02:54 PM
94si94cx
Jul 28, 2003 09:37 AM
