00 SI A/C compressor
did a quick look online at advanceauotparts.com and their Factory Air ac compressors w/clutch are the same part numbers for the 00si, 00ex, 00dx, 96ex and 94ex so therefore they should all be the same seeing how they all have the same part numbers.
that is totally wrong ... any b series compressor will work but a D series will only work if you want 2 bolts holding it on .... (doesent sound safe to me)
you need to use the Si ac bracket
sorry about that, i just looked real quick at the part numbers assuming since they were the same they would fit...if i got time at work tonight i'll pull an 00ex and 00si and see how they compare new maybe the new ones are a universal fit for both engines...unless ur looking for used then what was said earlier is ur answer...sorry for my bad
