DX wiring compared to Si
My friend and I are putting a b16 in his dx. I have done the swap in my Si already. Now, I have a spare Si engine wiring harness kicking around. Can we just sub that in for the DX harness and get the Si - SiR Hasport harness ($75 instead of like $200)
Lemme run that by you again.
DX harness - garbage
Si harness - replacing DX harness
HASport harness (Si to SiR) - added on to the Si harness.
Would this work? Once again, this would be nice because we would have 0 downtime as well as much cheaper seeing as how we have that extra Si harness.
if its intact, just use it...add the wires for the two extra injectors
add the 4 for VTEC....and make changes at the ECU..
its really simple.
cost= how much wire is at homedepot+solder+time hth
itztrixxx
Oct 26, 2006 07:25 AM
HondaHeddie
27
Oct 6, 2006 07:57 PM
Argetnia
Apr 7, 2005 11:54 PM
