Question for Type R owners with VAFC's - yay or nay
quick question.. i have a full jdm type R swap
only mods to the motor are intake/header/exhaust...
i have an oppertunity to get a vafc for $100
would you say they are worth it for my mild amount of mods?
easy to program/tune?
I would great appreciate any feedback..
also im missing my ashtray so it will fill the hole nicely
thanks
Chris
thanks
Chris
if u are going very minimal on the mods then i would say go for it, it is very limited though, cause it runs off the stock fuel maps of the car, and can only be altered to some extent so keep that in mind.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type_gsR »</TD></TR><TR><TD CLASS="quote">quick question.. i have a full jdm type R swap
thanks
Chris
Your just like me. JDM itr i/h/e and i bought a vafc2, but i still don't know if it's worth putting it. I have chipped p-28.
thanks
Chris
Stock ITR ECU no VAFC I/H/E =
Stock ITR ECU + VAFC ($100) + I/H/E and no Wide band O2/Air fuel gauge = worse than stock ECU (because it will always change with the weather/elevation and make you run too lean or too rich, and if you dont have a good Air Fuel gauge to know how your running then you are just guessing and that is worse than stock!)
Stock ITR ECU + VAFC ($100) + I/H/E and Wide band O2/Air fuel gauge ($400) = a pain in the *** cause any time the elevation/pressure/temp changes you have to mess with the VAFC settings to keep it within Stoich!
Either buy the VAFC for a Vtec point adjustment and a gauge or just save the $$ and buy somthing that you can get tuned once on a dyno and leave it alone!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmitr »</TD></TR><TR><TD CLASS="quote">Stock ITR ECU no VAFC I/H/E =
thanks for the info i have an AF gauge, but sounds like a hassle
and my dizzy just went out
TRQLESS
16
Feb 3, 2008 08:05 PM
Lifter2012
30
Apr 3, 2005 09:05 PM
