Won't shift!!
Old Sep 22, 2005 | 03:27 PM
jon1fox's Avatar
Default Won't shift!!
I have an 89 CRX with a B16A and Y1 transmission (cable). While I am moving and sometimes while I'm stopped I can't put it into gear. For instance, I'll turn the car on with it in first and the pedal pressed and sometimes the car will want to move foreward and if I have the brake on it dies. It's like the clutch is always at least partially engaged. It doesn't seem to be disengaging the clutch like it should. I checked to see if it needed to be adjusted cause I know there can be a little play in the cable over time. The lever that the cable connects to outside of the case seems to have full movement so I almost think it's something inside. Any ideas?
Jonathan
Old Sep 22, 2005 | 03:31 PM
Crx Jimmy's Avatar
Default Re: Won't shift!! (jon1fox)
screw the adjusting screw to the right so it gets tighter, try 3 turns and see if it helps if not try more
Old Sep 23, 2005 | 04:21 AM
B18c1-Crx's Avatar
i had the same problem if it isnt ur cable then most likely it is ur pessure plate but first check ur cable see if it is loose...
kricket3000
Sep 15, 2009 11:44 AM
EKIM NART
Mar 12, 2006 06:06 PM
CRX_Control
19
Nov 11, 2004 12:31 PM
Sirex
Sep 26, 2003 07:55 AM
