Blitz, Greddy Apexi GAUGE Blowout!!!
<FONT COLOR="Black"><FONT SIZE="3">We have had these gauge in stock for quite some time. These gauges are priced to move. In stock Sameday Shipping!!</FONT></FONT>
The electronic Racing Meter DC (Digital Compact) II series are one of the most unique gauges on the market. Succeeding its predecessor, Racing Meter DCII maintains the traditional dimensions and versatility of the Digital Compact Series - Featuring a depth of less than 1-inch and weighing 38 grams, the Racing Meter DCII can virtually be mounted anywhere in the vehicle. Available in Boost, oil/water Temperature, oil/water Pressure and with the addition of two new gauges: Speed/Power and Exhaust Temp/Rpm, the Racing Meter DCII is renowned as the most complete set of compact gauges available on the market. Available only in 60mm, Racing Meter DCII gauges come in: *New* Carbon, White, and Blue color-ways.
<FONT COLOR="DarkRed"><FONT SIZE="3">Gauge DC2 Boost Meter 2.0 Bar (Carbon)or white-$205.00 Shipped
Gauge DC2 Temp. Meter Oil/Water (Carbon)or white-$226.00 Shipped
Gauge DC2 Pressure Meter Oil/Water (Carbon)or white-$276.00 Shipped
Gauge DC2 Exhaust Temp./Rpm (Carbon)or white-$247.00 Shipped</FONT></FONT>
LINK UNIT FOR DC GAUGES-$125.00 SHIPPED
Identified by its "Black Light¨, the BLM (Black Light Meter) Racing Meter is the only gauge on the market featuring the unique black light illumination. Featured in a Carbon face and Chrome bezel, a black light bulb is installed in the front of the gauge; this process gives the meters a purplish fluorescent glow on the BLITZ® logo. BLM Racing Meters are available in Boost, oil/water Temperature, oil/water Pressure, and Exhaust Temperature. (Available only in 60mm, all gauges include necessary hardware and sensors.)
<FONT COLOR="Black"><FONT SIZE="3">Gauge BLM Boost 60mm Carbon Face Black Light-$164.00 Shipped
Gauge BLM Temperature Oil/Water Carbon Face Black Light-$199.00 Shipped
Gauge BLM Pressure Oil/Fuel Carbon Face Black Light-$237.00 Shipped
Gauge BLM EX. Temp EGT Carbon Face Black Light-$199.00 Shipped</FONT></FONT>
<FONT COLOR="Black"><FONT SIZE="3">GREDDY GAUGES IN STOCK</FONT></FONT>
<FONT COLOR="Purple"><FONT SIZE="3">60mm Mechanical Boost Gauge- White-$95.00 Shipped
60mm Mechanical Boost Gauge- Black-$95.00 Shipped
60mm Boost Gauge with Peak Hold & Warning, White-$174.00 Shipped
60mm Electronic EGT Gauge with Peak Hold and Warning- White-$179.00 Shipped
60mm Electronic EGT Gauge with Peak Hold and Warning- Black-$179.00 Shipped
60mm Electronic Oil Pressure Gauge with Peak Hold and Warning- White-$205.00 Shipped
60mm Electronic Oil Pressure Gauge with Peak Hold and Warning- Black-$205.00 Shipped
60mm Electronic Fuel Pressure Gauge with Peak Hold and Warning- White-$205.00 Shipped
60mm Electronic Fuel Pressure Gauge with Peak Hold and Warning- Black-$205.00 Shipped
60mm Air Fuel Ratio Blk-$239.85 Shipped
52mm Electronic Boost Gauge- White-$118.00 Shipped
52mm Electronic Boost Gauge- Black-$118.00 Shipped
52mm Electronic EGT Gauge- White-$137.00 Shipped
52mm Electronic EGT Gauge- Black-$137.00 Shipped
52mm Electronic Fuel Pressure Gauge- White-$137.00 Shipped
60mm Electronic Boost Gauge- White-$136.00 Shipped
60mm Electronic Boost Gauge- Black-$136.00 Shipped
60mm Electronic EGT Gauge- White-$158.00 Shipped
60mm Electronic EGT Gauge- Black-$158.00 Shipped
60mm Electronic Oil Pressure Gauge- White-$158.00 Shipped
60mm Electronic Oil Pressure Gauge- Black-$158.00 Shipped
60mm Electronic Fuel Pressure Gauge- White-$158.00 Shipped
60mm Electronic Fuel Pressure Gauge- Black-$158.00 Shipped</FONT></FONT>
<FONT SIZE="4">APEXI</FONT>
<FONT COLOR="Black">The EL II System Meters are the newest addition to the EL Meters lineup. The 60mm System Meters utilize a main control unit which constantly monitors the movement of all of the gauges. The control unit can activate the memory replay, warning, and peak hold functions with just one touch. The synchronized memory playback function was designed exclusively so that drivers did not need to individually start each meter before a race. A high speed CPU processor ensures accurate monitoring every time.
The main control unit can accommodate up to 6 meters. This gives the user unprecedented flexibility to decide what type of meter to add and how many. All meters come with a multi angle stand to allow easy reading from any vantage point. Since the main processor is not inside of the meter itself, A'PEXi engineers were able to slim down the meter casing so that it can be mounted virtually anywhere inside the cabin.
The high speed control unit processor also eliminates excess wires between the meter and unit. The EL backlit face uses a fresh new design that is easy to read. </FONT>
<FONT COLOR="Navy"><FONT SIZE="3">E.L. II Gauge Boost Kpa Black or White-$172.20 Shipped
E.L. II Gauge Oil Temp Black or White-$172.20 shipped
E.L. II Gauge Water Temp Black or White-$172.20 Shipped
E.L. II Gauge EGT Black or White-$187.00 Shipped
E.L. II Gauge Oil Pressure Black or White -$221.40 Shipped
E.L. II Gauge Fuel Pressure Black or White-$221.40 Shipped
E.L. II Gauge Meter Control Unit-$76.00 Shipped</FONT></FONT>
<FONT SIZE="4">
THESE ARE ALL ON CLOSE OUT SPECIAL. ALL IN STOCK SAMEDAY SHIPPING.
SAVE ON SHIPPING WHEN YOU BUY MORE THAN ONE GAUGE!</FONT>
<FONT SIZE="4">
