B18C1 Curiosity: JDM or Not JDM That Is The Question
Old Sep 22, 2005 | 01:44 PM
carbonlaced's Avatar
Default B18C1 Curiosity: JDM or Not JDM That Is The Question
I have a quick question if anyone else encountered this before, I swapped a 97 B18C1 into my Civic, in order to do the Swap I had to convert the motor (distributor and alternator) to OBD2 because they were OBD1 also my engine does not have a CKP (Crank Sensor) and no bracket or place to mount it, I know this usually means its OBD1 or JDM, but my block is Stamped B18C1 and year on the head is 97 anyone have any ideas?
Old Sep 22, 2005 | 02:01 PM
JimBlake's Avatar
Default Re: B18C1 Curiosity: JDM or Not JDM That Is The Question (carbonlaced)
I think the JDM engines were B18C without the "1" at the end.
Old Sep 22, 2005 | 04:04 PM
b18CrxSi91's Avatar
71.179.86.205
Default Re: B18C1 Curiosity: JDM or Not JDM That Is The Question (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I think the JDM engines were B18C without the "1" at the end.</TD></TR></TABLE>
Old Sep 22, 2005 | 08:01 PM
I already knew that, I was trying to figure out how a 97 B18C1 is OBD1 and does not have a CKFP Crank Sensor on it with no place to mount it like an OBD1 or JDM Motor
Old Sep 22, 2005 | 10:24 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (carbonlaced)
You sure its a 97? The date on the head could be different from the date of the block. OBD1 motors to not use crankshaft position sensors.
Old Sep 23, 2005 | 08:09 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbonlaced &raquo;</TD></TR><TR><TD CLASS="quote">I already knew that, I was trying to figure out how a 97 B18C1 is OBD1 and does not have a CKFP Crank Sensor on it with no place to mount it like an OBD1 or JDM Motor</TD></TR></TABLE>Sorry...
I think the first digit of the block serial # tells you the year. B18C1-1nnnnn is 1994 since that's the first year they were available. So a '97 would have 4 as the first digit. First digit zero is engines that were never installed at the factory. Like if you bought it at a dealer's parts counter...
But anyway, someone probably swapped the sensors over before you bought it.
shoklid
11
Apr 13, 2009 10:22 AM
JDMwhat
Dec 11, 2006 08:18 PM
Phatch99
Jun 10, 2005 05:35 AM
mikehawkBUiLT
Apr 6, 2005 12:34 AM
