Door ajar light in cluster.
Old Sep 22, 2005 | 12:32 PM
KraZyCHOWMEIN's Avatar
Default Door ajar light in cluster.
So this is the third integra that I've owned and this is the first time this has become an issue.
Problem: When making hard right hand turns the door ajar light comes on a bit the harder the turn the longer the light stays on. Now I noticed this only happens when my knee is barely braced against the door. I don't keep my foot on the dead pedal but rather on the kick panel just because it's easier for me to depress the clutch pedal quicker. Now when my knee is not braced against the door the light doesn't come on. Is there some sort of adjustment I can make to have the door shut tighter? I could keep my foot on the dead pedal but I'm used to bracing it against the door and it's not even pushing against the door that hard.
Other problem I have is I have the blackjax system... so if the door becomes ajar then you need to enter the code or the car shuts down thinking you've been carjacked, so you can see the problem here also.
Any input helps aside from keep your knee away from the door lol
TIA
Old Sep 22, 2005 | 12:46 PM
AssPenny's Avatar
Default Re: Door ajar light in cluster. (KraZyCHOWMEIN)
I believe you can move the latch in the door to adjust it. Or just put something to thicken up the tab on the door that makes contact with the switch. That would be your easiest solution.
One of thouse felt pad stickers would do the trick
Old Sep 22, 2005 | 12:48 PM
Mythias's Avatar
Default Re: Door ajar light in cluster. (AssPenny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssPenny &raquo;</TD></TR><TR><TD CLASS="quote">I believe you can move the latch in the door to adjust it. </TD></TR></TABLE>
Yep, that you can. I did that recently on my R. Takes a couple of minues with a phillips head.
Old Sep 22, 2005 | 12:50 PM
NICE Thank you Sirs!
Old Sep 22, 2005 | 12:54 PM
98DC2R's Avatar
I had that problem and I had to readjusted the silver latch with the 2 big philps screws. There are alignment marks on the latch and the door jam to line them up correctly.
Old Sep 22, 2005 | 03:35 PM
not something i want to do with my blackjax hooked up, kinda defeats the purpose.
Old Sep 22, 2005 | 07:17 PM
DC2 to AP2's Avatar
Default Re: (neo_)
ot, but how would you fix the trunk ajar? my trunk is open but the trunk indicator nor the trunk light comes on. any ideas?
Old Sep 22, 2005 | 07:25 PM
baonest's Avatar
Default Re: (imola-red dc2)
just tighten the assembly on the door jamb with the star tool. i did that. prob solved
Old Sep 23, 2005 | 07:22 AM
Sweet didn't know this problem was so common!
bochin
Dec 10, 2011 05:27 AM
SLOENUF
Feb 25, 2011 07:24 PM
951dc5
Jun 14, 2007 10:19 PM
4DRmafia
10
May 29, 2004 07:46 PM
Seedc2
Mar 13, 2003 03:24 PM
