another header question
Hey guys. got a quick question. heres my setup
i made 182.5whp and 131.1 tq full exhaust.
-wiesco 11.5 81.5mm pistons
-new bearings
-ARP rod bolts
-AEBS head studs
-JG valvetrain
-stock gsr valves and rods
-ITR cams
-JG cam gears
-Skunk2 intake manifold
-Hondata gasket
-Stock GSR TB
-Precision 310cc injectors
-Short ram intake
-ACT prolite flywheel/full face clutch
-shitty DC header 4-1 2'' collector
-Omni power test pipe
-Apexi N1 piping with summit turbo muffler
-Hondata s100
my question is, what header will make the most power on this setup without me having to spend 600+ dollars on a header.
also what cams other then the ITR's once i get a better header will make power with my compression?
please someone help
Modified by dc2kid at 3:19 PM 9/22/2005
-new bearings
-ARP rod bolts
-AEBS head studs
-JG valvetrain
-ITR cams
-JG cam gears
-Hondata gasket
-Stock GSR TB
-Short ram intake
-Hondata s100
please someone help
Well if you have a usdm DC header it has a 2" collector. If you don't want to spend more than $600 for a header, which I find interesting since you felt it was worth it to spend what $3000-$4000 or more on your build, then you should get a DC JDM or an OEM JDM ITR header.
swaytec360
Sep 14, 2005 11:16 AM
DANG YO
Jul 3, 2005 05:40 PM
