Hazard Light Not Working - 96' Honda Accord
Old Sep 21, 2005 | 10:34 PM
svselva's Avatar
Default Hazard Light Not Working - 96' Honda Accord
G'day,
The hazard lights on my Accord is not working. I figured it might be a burnt fuse.
What kind of a use do I need to replace the faulty one? Also, not sure, which particular fuse in the fuse box belongs to the hazard lights.
I'm not sure if this is a related problem. But when my faulty hazard lights switch has been turned on, my indicators doesn't work.
Will this be rectified by changing the fuse, or is there some other problem?
Appreciate the help guys.
Old Sep 22, 2005 | 10:29 AM
drktorn's Avatar
Default Re: Hazard Light Not Working - 96' Honda Accord (svselva)
does your radio work, hazard light fuse should be linked to your radio.
Old Sep 22, 2005 | 07:44 PM
svselva's Avatar
Default Re: Hazard Light Not Working - 96' Honda Accord (drktorn)
Radio and cd player working fine.
Old Sep 23, 2005 | 10:59 AM
deserthonda's Avatar
first off u need to make sure both fuses are ok,underhood fuse box , fuse # 35 15 amp.......underdash on the auxiliary fuse box , it is next to the fuse box upper left of it chk fuse # 12 7.5 amps,,,,,,,,,,,,,,.Do the turn signal work????,if fuses are ok u could have a bad hazard relay located underdash fuse box, or u could have a bad hazard switch,,, if fuses are ok then we will have to do some electrical diagnose to see which is bad
Old Sep 23, 2005 | 11:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drktorn &raquo;</TD></TR><TR><TD CLASS="quote">does your radio work, hazard light fuse should be linked to your radio. </TD></TR></TABLE>
no it isn't it is a totally different fuses
Old Sep 29, 2005 | 07:37 PM
svselva's Avatar
Default Re: Hazard Light Not Working - 96' Honda Accord (deserthonda)
Thanks.
I'll get it checked out on the weekend.
HondaTech101
Apr 7, 2007 06:59 AM
dylokjai
Dec 20, 2006 11:12 AM
integrakid
Dec 11, 2005 05:57 PM
V-Thang
Acura TL, RL & ZDX
May 28, 2005 11:33 AM
dra600n
Apr 7, 2004 11:21 AM
