rear lower tie bar
Old Mar 1, 2002 | 12:40 AM
au-gsr's Avatar
Default rear lower tie bar
guys i need a good pic of where a lower rear tie bar hooks-up to the chasis on a gsr-1994. i see a couple bolts that might work but i don't want to mess with any of them until i'm sure of where to install it. the only place it looks like i can install it might mess with the brake lines. i need your help!!!
Old Mar 1, 2002 | 01:31 AM
junglistgsr's Avatar
Default Re: rear lower tie bar (au-gsr)
the rear lower tie bar mounts up to where the LCA's mount to the subframe, there is a bolt that threads through the subframe and LCA......that line is an ABS sensor line and not a brake line and the bracket can be removed and the line zip-tied or re-routed without causing any problems.
twentyhurtz
Apr 20, 2009 06:45 PM
RIX982DRLS
Jan 2, 2005 04:43 PM
SWEETDUDE
Dec 16, 2004 08:26 AM
dLo GSR-stolen-now-WRX
Jun 19, 2002 11:55 AM
Alexander
May 8, 2002 01:22 PM
