ITR 5 lug setup with B16A2 motor need ITR axels?
Old Sep 21, 2005 | 09:40 PM
hondacivichatch's Avatar
Default ITR 5 lug setup with B16A2 motor need ITR axels?
Picking up a JDM ITR 5 lug setup and installing it on my '96 Civic hatchback CX which is going to have a B16A2 motor installed can I use the B16A2 axels or do I need ITR axels? The reason why I'm asking is because I was told the "thread" count is different? Any other options? Thanks
Old Sep 21, 2005 | 09:43 PM
jdmitr's Avatar
Default Re: ITR 5 lug setup with B16A2 motor need ITR axels? (hondacivichatch)
If it is a JDM setup then it will need the JDM ITR axles. The outer ends (splines) are larger like the ends on the Accords and Preludes.
Old Sep 21, 2005 | 09:45 PM
will the jdm itr axels bolt onto my b16a2 or will it be too large? Also is there anyway if I really wanted to, to get the spindles if thats what there called to match up with my axels? Thanks again!
Old Sep 21, 2005 | 11:09 PM
eg6sir-s's Avatar
do you have a picture of your 5lug setup? are you 100% sure that its a JDM ITR?
perseverance
Jul 9, 2010 06:11 PM
MenaceL.A.671
Apr 29, 2008 08:45 PM
GRPNHRD
Jun 22, 2007 03:19 PM
BIGthings
Feb 8, 2006 11:59 AM
hondacivichatch
Sep 29, 2005 08:38 PM
