ZC ( SOHC ) block/ Y8 head. What timing belt?
I'm a Jackass
Well i did a little research but i havent come up with a definate answer. I did however find 2 opstions. Use the Timing belt that coresponds to the head, in this case use the Y8 timing belt. the other is to use the Z6 Timing belt with my Y8/ ZC SOHC bottom end.
Any answers to this question???
thanks in advance.
Julio
thanks in advance.
Julio
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFRue57 »</TD></TR><TR><TD CLASS="quote">you would get the y8 timing belt.</TD></TR></TABLE>
I'm a Jackass
i found out that both the Z6/Y8 have the same amount of teeth (104)
so i guess i could use either. then again, the Y8 is like 20 dollars cheaper
