help obd0 ls in a crx si
Old Sep 21, 2005 | 04:45 PM
BMacls's Avatar
Default help obd0 ls in a crx si
need help i have 89 crx si i put a obd0 ls motor in with obd1 intakemanifold trying to run a obd0 ecu and i keep getting a iacv code.
Old Sep 21, 2005 | 06:34 PM
BMacls's Avatar
Default Re: help obd0 ls in a crx si (BMac_REX_TEG)
BUMP NEED HELP BAD
Old Sep 21, 2005 | 06:39 PM
Crx Jimmy's Avatar
make sure the iacv is plugged in, if it is try using the one from your stock si, it should fit fine, the ls one might be bad
Old Sep 21, 2005 | 09:24 PM
g-ride-si's Avatar
you can just clean it out too search and you will find tons on it.
Old Sep 24, 2005 | 06:05 PM
BMacls's Avatar
bump still need help
Old Sep 24, 2005 | 07:12 PM
Suck my DX's Avatar
i dont think u can use an obd1 iacv on an obd0 car...sensor is probably different between series....when the iacv went bad on my old b16 i put the one from my obd1 d15b7 on it...and it still threw a code...when i put a good one from an obd0b16 on it the code went away...it might not be the case but thats what happened with mine
Old Sep 24, 2005 | 08:07 PM
Rywire's Avatar
Default Re: help obd0 ls in a crx si (Suck my DX)
you can use either, u sure u have the correct plug in it?
Old Sep 25, 2005 | 07:47 AM
BMacls's Avatar
Default Re: help obd0 ls in a crx si (droppedcrxsi)
yes i know i have the right plug on it.
Old Sep 25, 2005 | 11:20 AM
Suck my DX's Avatar
the iacv could be clogged...it usually doesnt throw a code when its clogged...idles bad though and may cut off when the motor is still cold....if ur sure that the plugs are on correctly u need to check ur wiring to make sure that there are no opens in the circuit...have u tried a known working one? the one u got may have gone bad
lingo104
11
Jan 31, 2011 03:38 PM
nelsonb16
Jan 31, 2008 06:41 PM
Dr. D-Series
Oct 29, 2007 08:53 AM
milruner
May 10, 2005 10:50 PM
hybridej7
Jan 9, 2005 06:46 PM
