2K RPM B18B P75 Idle WTF ?! I Cant Figure This Out.. PLEASE HELP !!!
Old Sep 21, 2005 | 12:05 PM
93CharcoalHatch's Avatar
Default 2K RPM B18B P75 Idle WTF ?! I Cant Figure This Out.. PLEASE HELP !!!
ok heres the story.. i have a stock LS B18B with a stock P75 LS ECU and when im driving and i push the clutch to get out of gear or whatever the RPMS shoot up to around 2,000.. but then if i tap the gas while its at 2,000 it'll rev up like it should if u tap the gas and then fall back down to about 1,000.. and if i start driving again and im doing say 1,500RPM in 3rd and i push the clutch the will go up to around 2,000 RPM and sit there and idle there.. untill i tap the gas and then it goes back down to about 1,000 this is all while the engine is at normal operating temp. ANY IDEAS? PLEASE HELP!
i already tried resetting my ecu and no help there
Old Sep 21, 2005 | 12:17 PM
Default Re: 2K RPM B18B P75 Idle WTF ?! I Cant Figure This Out.. PLEASE HELP !!! (93CharcoalHatch)
need help ASAP because i need to know if i should be driving it or not
Old Sep 21, 2005 | 12:36 PM
ReDHaTcHyGuy's Avatar
did u check to see if the idle screw is backing out of the throttle body?
Old Sep 21, 2005 | 05:41 PM
Default Re: 2K RPM B18B P75 Idle WTF ?! I Cant Figure This Out.. PLEASE HELP !!! (ReDHaTcHyGuy)
checked and hasnt moved anymore ideas ??
Old Sep 21, 2005 | 05:44 PM
bman511's Avatar
my ls in my crx was doing that and it was the alternator going bad. Got a used one and hasn't happend since. Hopefully this might help, i'm not sure!
Old Sep 21, 2005 | 05:45 PM
Default Re: 2K RPM B18B P75 Idle WTF ?! I Cant Figure This Out.. PLEASE HELP !!! (bman511)
hmm
Old Sep 21, 2005 | 06:06 PM
dantastic's Avatar
throttle cable sticky? enough slack in it?
take off your intake and plug the hole in the throttle body that lets air go to the IACV. any effect?
Old Sep 21, 2005 | 06:15 PM
bman511's Avatar
let me know if the distributor works!
Old Sep 21, 2005 | 07:18 PM
bman511's Avatar
CORRECTION------------i wrote alternator the first time and ment to say distributor.
IT was my distributor
Old Sep 21, 2005 | 07:57 PM
civic_driver's Avatar
i would look at the throttle cable as well
Old Sep 21, 2005 | 08:32 PM
neutron91's Avatar
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">throttle cable sticky? enough slack in it?
take off your intake and plug the hole in the throttle body that lets air go to the IACV. any effect?</TD></TR></TABLE>
... throttle cable sticking or intake manifold gasket leak would be the first things i would check for
Old Sep 22, 2005 | 04:02 AM
Default Re: (neutron91)
throttle cable is only about 4 weeks old i guess i should check Distributor and Intake Manifold gasket
Old Sep 22, 2005 | 04:39 AM
bman511's Avatar
Default Re: (93CharcoalHatch)
also take off distributor cap, i've seen moisture get inside that cap. Clean it out
Old Sep 27, 2005 | 09:40 AM
Default Re: (bman511)
hmm tightened my loose squeeky alternator belt and it seems to idle fine now?? could this be all that was wrong?
Old Sep 29, 2005 | 05:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CharcoalHatch &raquo;</TD></TR><TR><TD CLASS="quote">hmm tightened my loose squeeky alternator belt and it seems to idle fine now?? could this be all that was wrong? </TD></TR></TABLE>
dvs94Teg
Apr 17, 2009 10:15 AM
psegs80
Aug 16, 2005 05:58 AM
iceman24
May 31, 2005 08:09 PM
