Good wide band o2 sensor...looking at LM-1 and M300
Old Sep 21, 2005 | 10:37 AM
KeyserSoze's Avatar
Default Good wide band o2 sensor...looking at LM-1 and M300
I searched and searched but was unable to locate a good explaination as to why some choose between these wide band o2 sensors (or others, I assume that these are the two chosen predominantly because they are decent sensors at affordable prices). I also read the faq's and found nothing. Just would like to know a couple of things from those who use wide band o2 sensors.
Which sensor?
Why (advantages, disadvantages, price)?
Where did you purchase it?
I am looking to learn how to tune, first on my upcomming b16 n/a setup (prolly will use crome), because I don't want to blow up my turbo setup (on aem). TIA.
Old Sep 21, 2005 | 10:56 AM
mmuller's Avatar
Mad Scientist
Default Re: Good wide band o2 sensor...looking at LM-1 and M300 (KeyserSoze)
I use zeitronix; you do have to have a laptop to use it unless you buy the display; but for the money, its the best choice.
Data logging is included.
It uses the bosch( vw) o2 sensor, which is the cheaper one( around $40); they say the bosh sensor sucks, but i have had it in the car for a while and still responds like new.
Modified by mmuller at 2:13 AM 9/22/2005
Old Sep 21, 2005 | 11:36 AM
KeyserSoze's Avatar
Default Re: Good wide band o2 sensor...looking at LM-1 and M300 (mmuller)
K, thanks for the response, really good info. Anyone else??
Old Sep 21, 2005 | 12:09 PM
Buzzbomb's Avatar
I went with the PLX M-300
I got it from a vendor here on HT for $299 shipped. I went with this one because all I really needed was a controller with a display. I’m using Uberdata which has datalogging built in so I wasn’t looking for extra software.
I was thinking about the Zeitronix because the price was in my budget but then I found out the display was extra and then I found out there were some compatibility issues with Uberdata, so I dropped it from my search. The compatibility issues are probably cleared up by now though.
Old Sep 21, 2005 | 05:22 PM
KeyserSoze's Avatar
Default Re: Good wide band o2 sensor...looking at LM-1 and M300 (Buzzbomb)
Anyone know if the Zeitronix works well with aem or crome???
Old Sep 21, 2005 | 06:14 PM
Sliced Beard's Avatar
the best WBo2 that I have used is the Innovate Technologies WBo2
You can get a RPM pickup and record your fuel maps for a specific amount of time. It works great for tuning and is extremely simple to use. It also uses a VW Bosch o2 sensor for price value and is a handheld unit so there is no need for a laptop.
Old Sep 21, 2005 | 09:22 PM
KeyserSoze's Avatar
Default Re: Good wide band o2 sensor...looking at LM-1 and M300 (DirtySol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtySol &raquo;</TD></TR><TR><TD CLASS="quote">the best WBo2 that I have used is the Innovate Technologies WBo2
You can get a RPM pickup and record your fuel maps for a specific amount of time. It works great for tuning and is extremely simple to use. It also uses a VW Bosch o2 sensor for price value and is a handheld unit so there is no need for a laptop.</TD></TR></TABLE>
Sounds like a nice unit, however no laptop is not a selling point as I will need (and already have) a laptop to tune my aem (when I feel comfortable doing so) and change the calibration files in it as well so I don't really care if it has a display or not. Thanks for the suggestion tho.
Old Sep 22, 2005 | 03:59 PM
The Innovate unit is also capable of using a laptop interface.....I just choose not to use it while I am doing any sort of street tuning. If I am on the dyno I use the Dyno's WBo2 system for the most precise comparison.
Old Sep 22, 2005 | 07:55 PM
machine4321's Avatar
i cant see any problems with runnign the zeitronix, it has a wideband out thats a 0-5v, any standalone should read it fine
ive got a zeitronix on the way with lcd and egt logging (it will be a great tunning aid )
KrazoMike
Dec 17, 2011 08:34 AM
civic disobedience
Sep 18, 2002 07:33 AM
AfEn808
Jan 21, 2002 05:51 PM
