Proof of the serious power of Hondata
Old Feb 28, 2002 | 09:17 PM
C-speed's Avatar
Default Proof of the serious power of Hondata
Here's about 15 mins worth of tuning with the Hondata unit coupled with a true IN-CAR wideband O2 unit that we have in-house - custom built unit. It took about 3 runs on the freeway to nail a near perfect 13.2 A/F without a dyno. Notice the intake charge temps:
Baseline:
After 3 runs:
The output of the wideband O2 is actually fed into the Hondata and it has the ability to log it and convert it to lambda or A/F.
Here's the Hondatalogger recording:
http://www.c-speedracing.com/temp/wideband.rec
[Modified by G3-TEG, 10:26 PM 2/28/2002]
Old Feb 28, 2002 | 09:25 PM
Bbasso's Avatar
Default Re: Proof of the serious power of Hondata (G3-TEG)
could you put that into a simple language like something i could understand please, One day i'll be able to read and comprehend in the same sec but for now...
And maybe if i know I'll be able to buy in the future>>>>>
But thanks for the info!!!
Austin's Avatar
Nice...
Old Feb 28, 2002 | 09:55 PM
Spikey's Avatar
hahahahahhaha...
teasing raging angel here a bit, cres???
Old Feb 28, 2002 | 09:58 PM
Austin's Avatar
Default Re: Proof of the serious power of Hondata (Bbasso)
Hondata has the feature to hook up a wideband O2 sensor to it, and tell it what your target AF is, you make a run, and it tells you how far you are off by, make changes, and you have the perfect AF ratio...then you go to a dyno to tune the gears and other items in...
Austin
Old Feb 28, 2002 | 10:09 PM
SlayANT's Avatar
Default Re: Proof of the serious power of Hondata (Austin)
The A/F is a lot better after just 3 runs
Old Mar 1, 2002 | 12:45 AM
RagingAngel's Avatar
Default Re: Proof of the serious power of Hondata (Spikey)
hahahahahhaha...
GRrRRRrrrrrrrrrRRrr.........Spikey you stay outta this or I will have RCMP on your *** for a car thas too low.....HAhaha.....j/k
Old Mar 1, 2002 | 12:50 AM
Spikey's Avatar
Default Re: Proof of the serious power of Hondata (RagingAngel)
my mouth is shut!
but can't wait to see how your car will be once cres gets the Hondata runnin on it!
Old Mar 1, 2002 | 02:08 AM
Drag_Dc2's Avatar
G3 - TEG,
Can you give any insites to this custom wideband 02 sensor? Did you guys make it yourselves? If so can you give details on how to make it and what is needed? How do you like this 02 sensor compared to others you have used??
Old Mar 1, 2002 | 02:45 AM
mr2's Avatar
mr2
Default Re: Proof of the serious power of Hondata (DragDc2)
hondata is sweet, anyone else see the ra file of the crx getting the hondata tests?
Old Mar 1, 2002 | 08:16 AM
STOLEN - ITR 98-0652's Avatar
I take it this is a Stage 4 set-up?
Personally, I have no need for "launch control", eh? I know the Hondalogger is an "option", but for NA applications, isn't a Stage 2 (with Hondalogger) adequate?
Old Mar 1, 2002 | 08:47 AM
RedlinedVTEC's Avatar
Default Re: Proof of the serious power of Hondata (ITR 98-0652)
Looks good Crescent, I'll be visiting you and Dave up in Bellingham this summer to get a hondata setup.
Old Mar 2, 2002 | 01:23 AM
C-speed's Avatar
For fuel and timing tuning (and vtec, redline etc) then yes - a stage 2 is really all you need - the datalogging option shouldn't be overlooked.
Keep in mind that only a dealer or someone with a stage 4+ can tune them though.. so if you do get a stage 2 or 3 unit, then you'll have to have someone to tune for you.
Old Mar 2, 2002 | 01:24 AM
GokuSSJ4's Avatar
nice , good work !!
Old Mar 2, 2002 | 04:44 AM
Short_Shifter's Avatar
G3-TEG :---- where did you guys get your IN-CAR wideband O2 unit ?
I would like to get one !
What was the cost ?
Question :- After you guys got your "PERFECT" A/F setup did you guys burn the chip to those settings ?
Did you go to the dyno before and after to see how much power you guys made ?
dumas07
Jun 13, 2007 06:24 PM
Blkteg97
Nov 1, 2004 08:45 AM
97CTR
Feb 17, 2004 11:31 AM
ActiveAero
Feb 19, 2003 06:53 AM
