Crx Pulsating, Vibration !!!!
Old Sep 21, 2005 | 06:47 AM
Rob.'s Avatar
Default Crx Pulsating, Vibration !!!!
Ok.. I have steering wheel vibration of course..... lol
Its a loud pulsating noise , that increases with speed. It's the worst at 60 mph .
So far I have:
- balanced the tires
- replaced both front wheel bearing 2 months ago...and it didnt solve the problem..
- did an alignment as well.
have been driving the car since then and the vibration is still there.
- I had the suspension checked by 1 mechanic and he said there's no play in both front wheels.So I am assuming the ball joints are ok.
What can it be ?
Can it be tie rod ends ? Inner ? Outer ?
Steering rack bushings ??
any help would be appreciated.
Old Sep 21, 2005 | 06:54 AM
CRX Toad's Avatar
Default Re: Crx Pulsating, Vibration !!!! (Rob.)
I'm not sure what kind of engine you have or what you do with your car but you may have a bent half shaft. If you have another set of axles or could temporarily borrow some I would try it.
I would also inspect all bushing in the front end. Look at the cross member bushing, tie rods, steering rack, etc.
Old Sep 21, 2005 | 06:59 AM
Rob.'s Avatar
Default Re: Crx Pulsating, Vibration !!!! (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">I'm not sure what kind of engine you have or what you do with your car but you may have a bent half shaft. </TD></TR></TABLE>
STOCK ENGINE..
Old Sep 21, 2005 | 07:22 AM
zccr-xsi's Avatar
hum how are your tie rod ends?and ball joints?how bout them bushings?
Old Sep 21, 2005 | 08:28 AM
Rob.'s Avatar
Default Re: (vteckillenzc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">hum how are your tie rod ends?and ball joints?how bout them bushings?</TD></TR></TABLE>
We shall see tomorrow..I'm taking her in to the operating room.
Old Sep 21, 2005 | 10:49 AM
stickershop.ca's Avatar
Default Re: (Rob.)
I had the same problem as you. It turned out to be a worn rack bushing. (The one just inside the end of the rack on the passengers side) It was causing play in the steering rack, so it would wobble ever so slightly. The vibration seemed to come and go. There was no specific speed at which it would vibrate consistently. Once I replaced that bushing, the problem was gone.
dc2JDMwhore
Suspension & Brakes
Oct 18, 2011 05:33 AM
f20cmx5
Jun 3, 2011 10:39 AM
j0keefe21
Feb 5, 2009 04:25 PM
sir91
Oct 31, 2003 09:43 AM
rscawley
Aug 6, 2002 10:12 AM
