Pennzoil Synchromesh?
Old Sep 21, 2005 | 02:58 AM
918-Hatch's Avatar
Colorado <3
Default Pennzoil Synchromesh?
So has anyone of you use the Pennzoil synchromesh? Will it ware any of the parts out in the tranny? jus wanting to know befor I put this stuff in my trans. I did a search and came up with a few but just wanted to know some long life type things. So if you have had this in your trans more then one time or ever have used it post up please.
Old Sep 21, 2005 | 04:44 AM
.water's Avatar
Default Re: Pennzoil Synchromesh? (918-Hatch)
dont bother other brands, stick with OEM or GM's
Old Sep 21, 2005 | 06:06 AM
90crvtec's Avatar
Default Re: Pennzoil Synchromesh? (JunkyDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunkyDC2 &raquo;</TD></TR><TR><TD CLASS="quote">dont bother other brands, stick with OEM or GM's</TD></TR></TABLE>
Pennzoil Synchromesh is the same as GM.
Old Sep 21, 2005 | 07:36 AM
PURPLETERROR aka BIGMATT's Avatar
who do you think makes synchromesh for gm?
Old Sep 21, 2005 | 06:47 PM
918-Hatch's Avatar
Colorado <3
bump
Old Sep 21, 2005 | 10:53 PM
Icey112's Avatar
Default Re: (918-Hatch)
it's the same as the gm<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90crvtec &raquo;</TD></TR><TR><TD CLASS="quote">
Pennzoil Synchromesh is the same as GM.</TD></TR></TABLE>
Old Sep 21, 2005 | 11:29 PM
918-Hatch's Avatar
Colorado <3
tight
Old Sep 22, 2005 | 07:39 AM
morningstar's Avatar
i used it in my tranny and it took a slight grind out of 3rd....jjust my experience though....i highly recommend it though
Old Sep 23, 2005 | 08:37 PM
918-Hatch's Avatar
Colorado <3
I guess no body else has used it huh?
Old Sep 25, 2005 | 06:33 PM
918-Hatch's Avatar
Colorado <3
bump this
Old Sep 25, 2005 | 06:40 PM
mmuller's Avatar
Mad Scientist
i use it if i cant get a hold of the friction modified version from GM.
Its great
What else would you like to know?
If you do a search for synchromesh or pennzoil synchro.
you will only get about 150 results....
There is TONSS of info on this...
elf
Aug 26, 2008 05:54 PM
lDanny
May 7, 2006 05:18 PM
Rene M
Aug 29, 2005 02:36 PM
rayman009
Mar 5, 2005 01:13 PM
Rasta
Oct 9, 2003 09:32 AM
