help !!! how to install the jdm DB8 type-r master power switch in my 95 4dr usdm integra?
Old Sep 20, 2005 | 09:53 PM
tkycgo's Avatar
Default Thanks !!! how to install the jdm DB8 type-r master power switch in my 95 4dr usdm integra?
I have successed to install this jdm type r 4dr cf swtich with type r door panels with no any modification. I have changed all the switch wires (16-pin) to other way. Now all the switches can work directly, only the front windows buttons are changed side. (because the auto button at right hand side)
Thanks all the guys. EnjoyTheRideDC2, ajantics, Naruto
Here are some pics.
HELP !!!!!
Anyone can teach me how to install the jdm db8 type-r master power switch (CF)
When I plug in with my usdm 4dr integra, now all the window's switches are not worked even if I have installed the oem switches.....
Modified by tkycgo at 1:58 PM 10/1/2005
Old Sep 21, 2005 | 10:04 AM
EnjoyTheRideDC2's Avatar
Default Re: help !!! how to install the jdm DB8 type-r master power switch in my 95 4dr usdm integra? (tkycg
You dont use the JDM master switch...
You use the CF surrounding and modify it to allow the clearance for the AUTO drivers window function and the window lock.
Then, using zip ties or any way you desire, you must "lock" the CF plate onto the USDM master switch.
Hard to explain without visuals, I'll try to take pics when I re-dynamat my doors.
Old Sep 21, 2005 | 10:13 AM
ajantics's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">You dont use the JDM master switch...
Hard to explain without visuals, I'll try to take pics when I re-dynamat my doors.</TD></TR></TABLE>
Exactly, my buddy don't have it no more so I don't have any pics. If I remember correctly you should dissconect your battery so that you don't blow any fueses as well!
I am going to be doing the same thing soon as well!
Modified by ajantics at 7:34 PM 9/21/2005
Old Sep 21, 2005 | 07:54 PM
tkycgo's Avatar
hi, EnjoyTheRideDC2
I am very pleasure for looking your post. You teach me a lot. How about the on/off button? How to make it fits?
I am waiting your pics a.s.a.p. and I will make the same way as you.
Actually, I want to change the electric wire for changing the R / L sides difference. If I can find the JDM service manual (RHD), I think that I can solve this problem.
Thanks again......
Modified by tkycgo at 9:13 PM 9/21/2005
Modified by tkycgo at 9:15 PM 9/21/2005
Old Sep 21, 2005 | 09:59 PM
Naruto's Avatar
Ummm...on my DC4 I used the master switch as well as the CF......and I didn't need to hack into the CF part or use any zip ties...:
here's two pics
no problems whatsoever
Old Sep 21, 2005 | 11:31 PM
ajantics's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naruto &raquo;</TD></TR><TR><TD CLASS="quote">
here's two pics
no problems whatsoever </TD></TR></TABLE>
There is a BIG difference in the wire-iring of a coupe a.k.a DC4/DC2 compared to the sedan a.k.a DB8. It is not a plug and play for the jdm DB8 sedan switches into a usdm sedan. It will not work, and you will always blow your fuses. Unless you want to re wire all the way to under the dash. Or you can just pop off your usdm switches and attach them on the faux carbon plate and make it work!
Old Sep 21, 2005 | 11:43 PM
tkycgo's Avatar
If I can find out the front L & R side switch's wires. can I change them to solve this button problem?
I have usdm service manual, if I get the JDM service manual, I think I can solve this problem (may be or not)
Thanks
Old Sep 21, 2005 | 11:55 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajantics &raquo;</TD></TR><TR><TD CLASS="quote">There is a BIG difference in the wire-iring of a coupe a.k.a DC4/DC2 compared to the sedan a.k.a DB8. It is not a plug and play for the jdm DB8 sedan switches into a usdm sedan. It will not work, and you will always blow your fuses. Unless you want to re wire all the way to under the dash. Or you can just pop off your usdm switches and attach them on the faux carbon plate and make it work! </TD></TR></TABLE>
I figured there might be since its split up between two doors on each side But to make it work....wouldn't you have to use a dremel or something because the problem I ran into with the JDM CF plates while trying to use the USDM master switch was that the "screw holes" on the JDM CF plate will not line up properly with the USDM Switch. Hmmm.....
Old Sep 22, 2005 | 10:27 AM
ajantics's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tkycgo &raquo;</TD></TR><TR><TD CLASS="quote">If I can find out the front L & R side switch's wires. can I change them to solve this button problem?
Thanks </TD></TR></TABLE>
I belive that you can, but If I remeber correctly we thought that we would ruin the acutally plastic wire harness. I think that if you take your time, there shouldn't be a problem! If you could do a thread on it with pictures that would be awsome!
Old Sep 22, 2005 | 10:29 AM
ajantics's Avatar
I figured there might be since its split up between two doors on each side But to make it work....wouldn't you have to use a dremel or something because the problem I ran into with the JDM CF plates while trying to use the USDM master switch was that the "screw holes" on the JDM CF plate will not line up properly with the USDM Switch. Hmmm.....</TD></TR></TABLE>
Yes you will have to modify the faux carbon plate a little! EnjoyTheRideDC2 is going to do the swap before I do, so hopefully he can get some pics up!
Old Sep 22, 2005 | 06:44 PM
I personally used a dremel and took my time....Gimme a couple hours and i'll have a pic.,
Old Sep 22, 2005 | 09:05 PM
tkycgo's Avatar
Anyone know how to find the JDM integra service manual?
I know that I can buy from ebay, but I am willing to find the link to download it.
Anyone can help me?
I am sure that I need to change the electric wires according to the JDM circuit.
Old Sep 22, 2005 | 11:52 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tkycgo &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know how to find the JDM integra service manual?
Anyone can help me?
I am sure that I need to change the electric wires according to the JDM circuit. </TD></TR></TABLE>
But that's only if you're doing what I did in using the JDM switches along with the covers. And the only reason I did it that way was because I did try the dremel thing so that I could use the USDM switch. It didn't work out too well...and I destroyed a perfectly good faux cf switch cover If you didn't want to do all that....wait until EnjoyTheRideDC2 posts the pics up. That way, you can go off of what he did and you won't have to spend as much money or time in re-doing your wiring harness for the windows. You could if you want. Its not hard...but a pain in the ***. But if you have the patience....just use the dremel.
Old Sep 23, 2005 | 12:05 AM
USE the USDM Switch! How is it harder to modify the CF surrounding as opposed to swappping wires and pins around?
Old Sep 23, 2005 | 12:10 AM
Naruto's Avatar
looks good.....now.....all we need is the pic of the underside of the cf switch cover. Unless....the screw holes line up? Coz...I know for the DC ones they don't.
Old Sep 23, 2005 | 12:29 AM
tkycgo's Avatar
Thanks so much EnjoyTheRideDC2, ajantics and Naruto
You are nice guys , you teach me a lot. I also want to post some pics on this page but I don't know how to upload pics.
I have same question for some button housing hole size. You help me to solve it. Thanks
You know, there is a 16 pin switch under the housing. What do you think if I can find out the JDM manual and USDM manual, I think that I can change the electric wires and then use the JDM switch. This is my dream. It doesn't matter for the front switches are changed way.
I don't want to use dremel to make some modification. If I make something wrong, the look will be so ugly.
Old Sep 23, 2005 | 12:54 AM
Old Sep 23, 2005 | 01:22 AM
tkycgo's Avatar
Do you need to drill the USDM switch for mounting the CF plate?
If I can change the wires.... all the thing is original parts for these JDM CF switches. No need to drill anything.
I understand what you teach me. Thanks a lot.
Old Sep 23, 2005 | 06:06 AM
gs-r da's Avatar
ill talk to sum of my friends and ill get back 2 you
Old Sep 23, 2005 | 11:09 AM
Naruto's Avatar
lol you double posted the same pics My question again was, what other modifications are done to the faux cf switch cover other than what you posted. I do know they screw into the switch assembly and from what I saw on the DC's, they won't line up at all if you're trying to use the USDM switch. So....with that in mind...do you have any pics of the underside of the cf switch cover? Or...do the screw holes line up in the DB's ( unlike the DCs ) ?
Old Sep 23, 2005 | 11:27 AM
They wont screw back together. I had to zip tie the assembly back together.
Old Sep 23, 2005 | 12:21 PM
CHONCH's Avatar
why would you waste money on this????
are the standard ones not good enough? lol
Old Sep 23, 2005 | 01:20 PM
Default Re: (CHONCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHONCH &raquo;</TD></TR><TR><TD CLASS="quote">why would you waste money on this????
are the standard ones not good enough? lol</TD></TR></TABLE>
Yeah, I agree with ya. I got sucked onto the JDM bandwagon for a bit, but can now say I've hopped off and snapped back to reality.
Old Sep 23, 2005 | 07:16 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnjoyTheRideDC2 &raquo;</TD></TR><TR><TD CLASS="quote">They wont screw back together. I had to zip tie the assembly back together.</TD></TR></TABLE>
well...it looks like a clean install. Hmmm.....so I take it people have tried to use the JDM switch and it did blow fuses.......hmmmm.....weird how it won't do that on the DCs.
Old Sep 23, 2005 | 11:04 PM
tkycgo's Avatar
hi all
I just want to ask you that I need to use the JDM all swtich parts because the front door panels which also are 98 JDM type r 4dr panels.
The perfect one which use the JDM switch too.
If I make some modifications, why I need to change it? I can use the original leather cover switch. (LS special)
Thanks
