HELP!! B18 SWAPPED 96 EK SPUTTERRING AND ACTING CRAZY!!!
Hey this problem started the other day.. these are the things that I noticed...
-Small amount of oil in the 3rd cylinder at the bottom... not much but there is a small amount...
-Valve Cover Seal Starting To Go Bad....
-I thought it would be the ignition coil so I replaced the coil and I bought new spark plugs and nothing got better that day...
-Then 2day I started the car and it sputtered out and died and i smelled gas from the intake filter... then i started it again while holding the gas down and it revved out and I drove it off and had no more problems revvin it to only about 3k or so before shifting gears...
-When i drove it back home 2day I tryed to rev it to see how it would respond and it would sputter when the revs got around 4k or so.... I dont know what else could be causing this problem...
-Any ideas?? I need 2 fix this problem ASAP... Thanks
ok UPDATE.... I fixed the main problem... the tps sensor wuz loose... now no sputtering until i hit high rpms.. meaning 5k and up... any ideas why it would sputter now??
Thanks and plz help!!!
bump... now it is onyl sputtering ocasionally after 5k rpms and the tach goes crazy while the sputtering occurs... any ideas anyone??? plz... i need 2 figure this out...
w1ckedboy504
Jan 18, 2010 12:58 AM
JDM_EK_wanabe
Oct 13, 2006 10:05 AM
