Modifying clutch pedal? *too long of a push*
Old Sep 20, 2005 | 07:49 PM
Don Johnson's Avatar
Default Modifying clutch pedal? *too long of a push*
The clutch pedal in my car is stupid long before it engages, and its bothering the hell out of me and I cant get comfortable driving it the way it is. So my question is, is it as simple as adjusting the screw forward to push the pedal closer to the firewall?
I have a cable tranny, so would moving the clutch pedal forward create slack and require adjusting?
Sorry, I sound like an idiot, but my DA pedals never felt like this and I cant get use to it.
Any help is appreciated
Old Sep 20, 2005 | 11:43 PM
sporkcrx's Avatar
Default Re: Modifying clutch pedal? *too long of a push* (Monguse)
Is it engaging too high or too low? You can adjust the engagement point via the cable **** on the tranny. Follow the cable down to where it gets near the tranny, and there is a black plastic ****.
Old Sep 21, 2005 | 05:44 AM
steronz's Avatar
yay, i can provide helpful insight for once!
i was annoyed about the same thing, so here's what i did. there's a bolt, maybe an inch and half long, that controls how far from the floor your clutch pedal travels before it stops. this bolt is positioned by a nut that locks it against a bracket on the pedal assembly... the nut can be turned to adjust the distance. i simply took that nut out and cranked the bolt all the way down. this made the clutch pedal stop about 6-8 inches from the floor instead of 14 inches or whatever the ridiculous number is when stock. then i adjusted the clutch cable accordingly... it took a few hours of adjusting, driving, adjusting, driving, etc, to work with the smaller travel to get just right, but i wouldn't have it any other way. i've been driving this way for about 5,000 miles with no ill effects.
Old Sep 21, 2005 | 11:52 AM
sporkcrx's Avatar
Default Re: (steronz)
Nice, I might have to try that
89civicsiowner
May 24, 2009 05:29 PM
kdsmonitor
Oct 13, 2008 07:35 PM
jwbnavy
12
Dec 2, 2007 06:36 PM
crxgator
12
Mar 21, 2004 09:30 AM
FullMetalJacket
Mar 19, 2003 03:08 PM
