AGX setting question?
i just got my agx's. i was wondering wat everyone who has AGX's settings were in the front and in the back. i got the top dial one with only 4 settings. i more looking for a comfy ride setting.
thanks
thanks
Well, as you probably know 1 is the softest, and 4 is the tightest.
I'm not sure what your definition of "comfy" is. If it's soft, then set them all soft. If you want better handling to achieve a more neutral handling car (or even more toward oversteer), you want to have the rear tighter than the fronts.
When I had mine, I had the rears at 4 and the fronts at 2. What type of other suspension components do you have? Thicker rear sway bar? Springs?
