lsvtec youll love this bad boy
Old Feb 28, 2002 | 07:42 PM
vtecpower11's Avatar
Default lsvtec youll love this bad boy
ls block with CTR pistons
gsr head
itr valve springs
Skunk2 Intake Manifold
JDM DC sport headers
Injen CAI
GREDDY EVO
VAFC
bigger injectors
all in a 95 civic coupe
now isnt that a bad *** setup
revlimit is set at 8500
now all i need is some cams...not sure tho..can someone help me out here,
i was thinking of Skunk2 Stage 1 cause of money
but what do you people suggest?
and am i gonna run into pistons clearence problems.....
[Modified by vtecpower11, 1:17 PM 3/5/2002]
Old Feb 28, 2002 | 08:53 PM
Liquidx02's Avatar
Default Re: lsvtec youll love this bad boy (vtecpower11)
ported and polished block?
Old Mar 1, 2002 | 03:36 AM
Default Re: lsvtec youll love this bad boy (Rattlesn8ke)
yea...it is...you can port and polish anything in a car, people keep askin...yes you can port and polish a block the cyclinders.....
Old Mar 1, 2002 | 05:12 AM
lube's Avatar
Just like you can milk anything with nipples, right?
Old Mar 1, 2002 | 05:58 AM
JD_B18CDX's Avatar
Default Re: lsvtec youll love this bad boy (lube)
Polish the block??
What good that does that do? Is it just for show?
Old Mar 1, 2002 | 11:41 AM
Default Re: lsvtec youll love this bad boy (johnd)
inside the cylinders...and um..increase airflow....
Old Mar 1, 2002 | 11:48 AM
WAFFLES's Avatar
hahahahaha....increase airflow!
Old Mar 1, 2002 | 01:03 PM
Default Re: lsvtec youll love this bad boy (WAFFLES)
yea call portflow the will tell you that too...cause they did it for me...andd napa did the head....
Old Mar 1, 2002 | 01:31 PM
ekekek's Avatar
gsr head and CTR pistons!!! damn, your compression must be through the roof.
Old Mar 1, 2002 | 01:32 PM
boomslang's Avatar
Hahaha, that's hilarious!
Old Mar 1, 2002 | 01:37 PM
Solo2Vtec's Avatar
Default Re: lsvtec youll love this bad boy (Inlinefour)
Hahahahahahahahahahahah
Old Mar 1, 2002 | 02:19 PM
Finest's Avatar
Did I read this right? LMAO!
Old Mar 1, 2002 | 03:40 PM
Erik_Pb_Foot's Avatar
New User
Default Re: lsvtec youll love this bad boy (Prelude_RCR)
hummmm
well either way... i'm gonna go ahead and ask for a dyno and your compression ratio... sounds... sounds like it could be quick though
Old Mar 2, 2002 | 08:40 PM
Default Re: lsvtec youll love this bad boy (Pb_Foot)
havent dynoed yet....but compression is like 12:6 to 1
Old Mar 2, 2002 | 10:25 PM
xJ.SLOTHx's Avatar
is this a joke?
Old Mar 3, 2002 | 02:32 PM
mingchi96
Guest
Posts: n/a
Default Re: lsvtec youll love this bad boy (ian)
you cant port and polish a block, the cylinder walls are supopse to be kind of rough, in order for the rings to seat properly. Nobody ported your cylinder walls, if they did, they are the dumbest dumbass Ive ever heard of. You must have gotten mixed up with honing a block and thought that must have meant port and polish.
Old Mar 3, 2002 | 03:02 PM
slowerthanu's Avatar
New User
Default Re: lsvtec youll love this bad boy (mingchi96)
You can polish the wall of the block (not sleeves but the inner wall's, this removes built in sand left over from the casting process). You should not polish the cylinder sleeves because of the above mentioned reason. You need a good hone job in order for the rings to seat properly. If portflow DID polish your cylinder wall's, then I dont believe I will be having them perform any work on my car
Old Mar 3, 2002 | 06:36 PM
Tomakit's Avatar
So they polished the area where the coolant resides for "increased airflow"?
Hmmm, something about this just doesn't sound right.
Tom
Old Mar 3, 2002 | 07:21 PM
ekekek's Avatar
Default Re: lsvtec youll love this bad boy (Tomakit)
its for increased coolant flow duh
Old Mar 3, 2002 | 07:25 PM
SpooN Man's Avatar
Default Re: lsvtec youll love this bad boy (ekekek)
you sound like a retard
Old Mar 3, 2002 | 08:34 PM
Denny317's Avatar
LOL
EGtypeR408
10
Jan 30, 2011 05:20 AM
shatchi
13
Apr 7, 2006 06:27 PM
lowkeyciv
Apr 25, 2003 03:57 PM
