Little Clutch Problem
Old Sep 20, 2005 | 05:19 PM
Curtis2kul's Avatar
Default Little Clutch Problem
Here recently ive noticed that my clutch is lightly grabing when i "pull" in the clutch. Sometimes i can hold in the clutch at a stop and fell the bike start to move a little. Its not insane but i know its not supposed to do that. Its a hydralic clutch so i have no idea what the problem could be. Any suggestions?
Old Sep 21, 2005 | 02:09 AM
rogaB's Avatar
what make/model bike is it? it should have a clutch tension adjustment on it. most usually by the clutch handle itself
Old Sep 21, 2005 | 07:33 AM
integrator43's Avatar
Default Re: Little Clutch Problem (Curtis2kul)
since it is a hydraulic clutch setup you need to look at your master cylinder, your slave cylinder, and all hoses/lines and connections.
first, check the service manual.
second, check the fluid level in the resevoir.
third, if the fluid is low find out where it is leaking.
fourth, repair the problem.
good luck!
Old Sep 21, 2005 | 08:10 AM
turboH22Aakkord's Avatar
Default Re: Little Clutch Problem (integrator43)
check the clutch fluid to see if its full and bleed that mother (make sure you check to see what type fluid you need... i just bleed my clutch a while back and it asked for DOT 4 fluid where almost every other clutch ive ever done used DOT 3)... that might help?
Old Sep 22, 2005 | 12:50 PM
Curtis2kul's Avatar
Default Re: Little Clutch Problem (turboH22Aakkord)
its a 90 kawasaki zx7. The resevoir is full. It hasnt changed levels at all. Rode it yesterday and havnt had any problems
htwannabi
Nov 28, 2008 09:40 AM
always smooth
Jan 25, 2008 10:19 AM
OSG 97 ITR
Apr 17, 2004 10:11 AM
neogenesis2004
Mar 28, 2004 10:19 PM
type_sml
Aug 23, 2002 12:53 PM
