A few Fuel related questions
Old Sep 20, 2005 | 03:34 PM
BlendedEJ8's Avatar
Default A few Fuel related questions
ok, i have a '99 civic coupe ex. swapped in a 1999 LS swap, jumpered to OBD1. now, one of my problems (which i've had since i swapped it in dec.2004) is when i go get gas.. when i take the cap of the tank, i can hear that there is a good amount of pressure that is being released. when i fill it up and,put the cap back on and start it up however, it does not want to idle. it stalls out i have to hold the rpms at about 1500 for a few minutes. my question is this, would swapping out the stock civic ex SOHC fule pump for say a GSR fuel pump help? also, lately my car has been driving funny and it happens speradicaly(sp). if im at a low throttle level, say like 20-30%, the car starts to bog down as if it were out of gas. now, if i go and give it more throttle like 70% it jumps back up. i changed my fuel filter, added a pressure guage and my pressure is at 30-35psi. could this be a regualtor issue or even an injector issue? i am also throwing a code43 for this i might add, but the code star5ted popping up wen the the car starting its bogging thing. any information that may shed some light for me would be greatly appreciated.
TIA H-Techers
Old Sep 20, 2005 | 07:21 PM
BlendedEJ8's Avatar
Default Re: A few Fuel related questions (BlendedEJ8)
anyone?
Old Sep 20, 2005 | 07:26 PM
civic_driver's Avatar
i think the fuel pump should be fine.. you might need to use an adjustable fpr to raise the pressure a little bit... seems like you need more fuel
try this.. remove the vacuum from the fpr and try to start the car like that... if it doesn't start, you might need to upgrade your fuel pump/fpr if it's a fuel problem
btw, did your car come with the fuel rail/injectors/fpr from the LS? if so it's most likely your fuel pump
Old Sep 20, 2005 | 07:46 PM
BlendedEJ8's Avatar
Default Re: (civic_driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_driver &raquo;</TD></TR><TR><TD CLASS="quote">try this.. remove the vacuum from the fpr and try to start the car like that... if it doesn't start, you might need to upgrade your fuel pump/fpr if it's a fuel problem
btw, did your car come with the fuel rail/injectors/fpr from the LS? if so it's most likely your fuel pump</TD></TR></TABLE>
yes, it all came together as one. i think imma just through in a spair GSR fuel pump and see what come outta it. i'll let ya know
Old Sep 20, 2005 | 08:08 PM
yeah, i'd try the start without vacuum to fpr first just to confirm that your stock pump can/can't handle it
slow_low_eddie
90
Sep 3, 2014 05:46 PM
b_boysaiyan
Jan 20, 2014 11:41 PM
B_Swapped93
May 11, 2013 02:08 PM
Maple50175
Jul 13, 2010 02:12 PM
soundbomber
Feb 6, 2005 12:23 PM
