whats the widest rim your running on?
i'm considering on getting a set of slipstreams (16x8). is this to wide? should i go with 16x7? what are you guys running on? any problems with rubbing? how's the handling and ride? help me make up my mind!
thanks
thanks
What kind of car? What make/model and size tires do you plan on using? Is this for street use, or the dragstrip, or the racetrack, or winter tires?
Modified by nsxtasy at 6:16 PM 9/20/2005
Your Civic probably came with 175/70-13 or 185/60-14 tires. The closest match in a 16" size is 205/40-16. Most tires in that size are approved for mounting on rims with width of 7.0 to 8.0 inches - so it's possible to use 16x7 or 16x8.
checkster2000
12
Aug 5, 2005 03:31 AM
