Installing JDM 92-93 Bumper/Bumper Support on 1990 DA Integra
From: Derek Jeter drinks wine coolers,, The Nation, USA
So I just got my 92-93 JDM Bumper w/ JDM support from Password the other day. But the support is about 3 inches from lining up with were it should mount to my chassis. What should I do? Make a custom bracket? Is there a JDM mount I can buy?
From: Good luck to this industry, you're gonna need it.
try http://www.g2ic.com for some answers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAantagonist »</TD></TR><TR><TD CLASS="quote">try http://www.g2ic.com for some answers</TD></TR></TABLE>
Thanks
I've looked
Thanks
I've looked
i believe you have to use the 92-93 brackets (the part that the bumper support bolts up to) check g2ic.com again. i remember there being something about it on there. if i find it before you do i'll post it up for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tngay »</TD></TR><TR><TD CLASS="quote">jsut use ur stock bumper support and put ur bumper on. everything should work for it.</TD></TR></TABLE>
It weighs like 20 lb.s more, I don't really want to
oh and this way is possible also.. thats how i installed my 92-93 bumper. but its a really really tight fit with the bumper cover. also you can't reuse the foam between the support and bumper cover.
ok.. well nm then if you wanna drop the weight. lol
I've been wondering about this too. My only issue has been puting a 92-93 usdm bumper, paired with a jdm support on to my 1992 integra. The bracket sits, like you said, about 3-4 inches away from the stock brackets.
I'm wondering if I could get the JDM brackets to mount to the chassis?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Convoy »</TD></TR><TR><TD CLASS="quote">i just switched the supports from the 90-91 - 92-93 support. It was real easy</TD></TR></TABLE>
JDM? USDM?
JDM? USDM?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by theSYNDICATE »</TD></TR><TR><TD CLASS="quote">JDM? USDM?</TD></TR></TABLE>
the front of the 90-91 are jdm and the 92-93 r us
Use the USDM 92-93 bumper mounting thingy, there's two of them, one on each side. Then the JDM support should line up no problem.
If you want, i can take pictures of mine tomorrow.
Thanks guys, I will check out a junkyard and see if I can get some.
88 civic ef
May 31, 2006 07:51 AM
