Turbo'ing at 110,000 miles??
Old Feb 28, 2002 | 06:39 PM
TeamTooQuick's Avatar
Default Turbo'ing at 110,000 miles??
Ok, im planning on buying a drag gen III turbo kit, and i just got done reading a post saying its not good 2 turbo a car with over 100,000 miles on it, well my car has been baby'd like crazy for 108,000 miles of the 110,000 thats on it now, so its just like its new, and its a HONDA motor!! lol, but im askin yall, would it be ok if i turbo it with about 6.5 or 7 psi with the mileage??
Old Feb 28, 2002 | 06:41 PM
Jesse H's Avatar
Default Re: Turbo'ing at 110,000 miles?? (TeamTooQuick)
check your compression, do a leakdown test, maybe even dyno it to see if it's on par with other motors with the same mods, if any. Does it burn or leak any fluids?
That'll give you a good indication of the shape of the motor.
Old Feb 28, 2002 | 06:43 PM
VtecDeMoN's Avatar
Personally I wouldn't risk it. That'sa pretty high mileage motor. Before going turbo I'd tear the block apart and rebuild it, new seals, gaskets, bearings, bore it .25 over and add low compression forged pistons the works. You might also want to consider purchasing a used block with lower miles and building it up with forged internals. If you are looking for reliability out of your car slapping a turbo kit on an engine with that many miles will be fun for as long as the motor will hold out and then you'll have to rebuild or buy another one anyways. Just my .02 cents.
Brian
[Modified by VtecDeMoN, 4:09 AM 3/1/2002]
Old Feb 28, 2002 | 06:46 PM
TrustGs-R's Avatar
New User
Default Re: Turbo'ing at 110,000 miles?? (VtecDeMoN)
i'm with Vtecdemon...
you're just asking for trouble.
Old Feb 28, 2002 | 07:39 PM
Default Re: Turbo'ing at 110,000 miles?? (TrustGs-R)
Anybody else??
Old Feb 28, 2002 | 07:44 PM
Vazquez911's Avatar
Anybody else??
Yeah, I like your (Advanced Engine Management Central Intelligence Agency) mod... I bet it's MAD fast y0! Plus, my strut bar sucks... I heard sturts are a better brand!!!
Find a used block... build it, sleeve it... make it a bulletproof monster. Then boost the shat out of it. Oh yeah, better replace ur axles, CV joints, bearings, blah blah blah... cause 110k miles isn't going to hold lots of torque for long. Things will start breaking.
Good luck!
[Modified by Vazquez911, 10:45 PM 2/28/2002]
Old Feb 28, 2002 | 09:16 PM
nfn15037's Avatar
Default Re: Turbo'ing at 110,000 miles?? (Vazquez911)
[QUOTE]Anybody else??
LOL
Old Feb 28, 2002 | 09:46 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Turbo'ing at 110,000 miles?? (nfn15037)
I turboed my LS at 115,000 miles. At 118K miles, I spun a rod bearing. This probably has nothing to do with the turbo, but I don't know.
I didn't have much oil in it, so it must have burned pretty fast. Hmph. So I guess the turbo did cause it.
brent_si
Apr 16, 2007 12:22 PM
fitpro104
Apr 4, 2007 01:37 PM
98blkgsrteg
Aug 5, 2006 06:15 AM
xxtruoutlawzxx
Mar 14, 2004 03:17 PM
b18tdelsol
Apr 17, 2002 10:34 PM
