NEED HELP READING THE CODES
reading you ECU code means you need to remove the carpet where your passengers feet will usually be. You'll see it. There should be a hole in the middle with a red blinking light (if the CEL light is indeed on). Count how many times it blinks, because each number of blinks refers to a specific problem. Hope that helps.
my bad about caps lock its just that i am at work and i type all my stuff in caps so its all ways on
now with the codes it just keeps going how do i know when it restarts
Spoolin'VW
15
Nov 19, 2005 03:27 PM
lgragera
Aug 6, 2005 05:15 PM
97gSrkId88
Mar 20, 2003 11:06 PM
