Help! Whats Best For Swap D16Z6 or ZC Vtec?
Old Sep 20, 2005 | 07:09 AM
93SiHB's Avatar
Default Help! Whats Best For Swap D16Z6 or ZC Vtec?
Hello my D16z6 has just gave its last 40 miles now im looking to either get the same engine or the Vtec ZC but what i wanna know is which would be best to swap in and are the parts in the ZC interchangeable with the D16z6 such as waterpump Timing belt and distributor?
Old Sep 20, 2005 | 07:38 AM
FoRd FoCuZ 4 Life's Avatar
Default Re: Help! Whats Best For Swap D16Z6 or ZC Vtec? (93SiHB)
just go with a b16. or maybe an LS (b18b) motor for around 800 if you cant afford a b16. i know it doesnt seem like your going crazy for power but you do want a little more than wat your stock had. id say b18b!
Old Sep 20, 2005 | 08:09 AM
JDMroyEG5turbo's Avatar
ZC have more high compression from the d16z6. its almost the same
but the ZC it a little bit stronger.
if you need to choose. b16a its much better for you
roy
Old Sep 20, 2005 | 08:27 AM
93SiHB's Avatar
i like the b16a idea but that not really an option for me do to mpg i gotta drive to work pretty far and i was getting over 30mpg on the D16Z6 if i could id already have a b18 with the b16 head
Old Sep 20, 2005 | 09:58 AM
d16singlecammer's Avatar
Default Re: (93SiHB)
I have a ZC vtec and I must say that its a pretty strong engine for what it is. All the parts are interchangeable between the Z6 and ZC vtec. Just go with a ZC Vtec from an engine importer because more likely than not it will have lower miles than a Z6 that you'll get from the classifieds.
Old Sep 20, 2005 | 10:38 AM
civic_driver's Avatar
does zc accept boost well? with higher compression numbers i'm think z6 would be better suited for boost
93SiHB's Avatar
Default Re: (d15singlecammer)
so can i just go out and get the timing belt and water pump and plugs for the Z6 and use em on the ZC?
Old Sep 20, 2005 | 10:50 AM
Yes <U></U>all<U></U> the parts are interchangeable, and I don't believe the higher compression is significant higher that it will affect boost. I was always told that the compression between the ZC Vtec and Z6 are identical but who knows? According to some the ZC Vtec does have higher compression and the same cam as the D15B which is slightly more aggressive. But they are all myths until some one could show proof of it
Old Sep 20, 2005 | 05:26 PM
93SiHB's Avatar
heres what i was told over at the civic forum which is why im very confused
Here's the part numbers and/or what they come off of.
Alternator Belt
31110-PM5-305
88-91 CRX Si
A/C Belt
38920-PM5-A04
88-91 CRX Si
RT Engine Mount
50805-SH3-040
88-91 CRX Si
LT Engine Mount
50821-SH3-040
88-91 CRX Si
Frt Engine Mount
50840-SH3-000
88-91 CRX Si
RR Engine Mount
50810-SH3-040
88-91 CRX Si
Thermostat
19300-PM3-003
88-91 CRX Si
Thermostat Gasket
19308-PJ7-000
88-91 CRX Si
Water Pump
19200-P01-004
88-91 CRX Si
Oil Pan Gasket
11251-P01-004
88-91 CRX Si
Lower Radiator Hose
19502-PM3-000
Crank Seal
91212-PE0-662
1989 Integra
RR Main Seal
91214-PH1-013
1989 Integra
Cam Seals
91203-PG6-013
1989 Integra
H/C Cover Gasket
12341-PM7-000
1989 Integra
Dist Cap
30102-PM7-016
1989 Integra
Dist Rotor
30103-PM5-A05
1989 Integra
Ex Manifold Gasket
18110-PG6-003
1989 Integra
Intake Gasket
17105-PG6-s00
1989 Integra
Head Gasket
12251-PM7-003
1989 Integra
Timing Belt
1988 Prelude 2.0
Old Sep 20, 2005 | 05:32 PM
junior40er's Avatar
D15B 1.5L SOHC VTEC&gt;Twincam ZC&gt; D16Z6&gt; ZC vtec
Old Sep 20, 2005 | 05:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93SiHB &raquo;</TD></TR><TR><TD CLASS="quote">heres what i was told over at the civic forum which is why im very confused
Alternator Belt
31110-PM5-305
88-91 CRX Si
A/C Belt
38920-PM5-A04
88-91 CRX Si
RT Engine Mount
50805-SH3-040
88-91 CRX Si
LT Engine Mount
50821-SH3-040
88-91 CRX Si
Frt Engine Mount
50840-SH3-000
88-91 CRX Si
RR Engine Mount
50810-SH3-040
88-91 CRX Si
Thermostat
19300-PM3-003
88-91 CRX Si
Thermostat Gasket
19308-PJ7-000
88-91 CRX Si
Water Pump
19200-P01-004
88-91 CRX Si
Oil Pan Gasket
11251-P01-004
88-91 CRX Si
Lower Radiator Hose
19502-PM3-000
Crank Seal
91212-PE0-662
1989 Integra
RR Main Seal
91214-PH1-013
1989 Integra
Cam Seals
91203-PG6-013
1989 Integra
H/C Cover Gasket
12341-PM7-000
1989 Integra
Dist Cap
30102-PM7-016
1989 Integra
Dist Rotor
30103-PM5-A05
1989 Integra
Ex Manifold Gasket
18110-PG6-003
1989 Integra
Intake Gasket
17105-PG6-s00
1989 Integra
Head Gasket
12251-PM7-003
1989 Integra
Timing Belt
1988 Prelude 2.0 </TD></TR></TABLE>
OH man are you confused, the parts that you listed are for a twin cam ZC. Your original question was which is better a D16Z6 or a ZC VTEC (which is IDENTICAL to the D16Z6). My answer to your question is a ZC VTEC because.
1. I have one
2. Engine will generally have lower miles=most of the time equals a better performing engine
3. ALL the D16Z6 parts are interchangeable
Good Luck
Old Sep 20, 2005 | 06:04 PM
Default Re: (junior40er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junior40er &raquo;</TD></TR><TR><TD CLASS="quote">D15B 1.5L SOHC VTEC&gt;Twincam ZC&gt; D16Z6&gt; ZC vtec</TD></TR></TABLE>
Got any proof to back up your statement.
For one the D15B has slightly less torque than any of the engines you listed. Second the D15B has less aftermarket support (engine internals). Sure a D15B is a great engine, in fact I bought one about a year ago and decided to go for a ZC VTEC because of all the aftermarket support and because all the D16Z6 parts are compatible. I didn't want to mix and match parts when it came down to a D15B.
In my OPINION
D16Z6=ZC Vtec&gt;D15B&gt;Twincam ZC should'nt even be in this equation
Modified by d15singlecammer at 4:17 AM 9/21/2005
Old Sep 20, 2005 | 07:17 PM
where can you get the zc vtec?
Old Sep 20, 2005 | 07:21 PM
Default Re: (civic_driver)
I got mine from Steve from hmotorsonline.com, I got my swap along with a D15B S20 for $645 + tax. Very clean engine and very strong, I wouldn't deal with no other engine importer.
Old Sep 20, 2005 | 07:24 PM
where is the zc vtec? i don't think i saw one on there.
Old Sep 20, 2005 | 07:31 PM
It is not on the site, but if you contact Steve by phone and ask him for a ZC Vtec he will give you a price. I don't believe Steve carries the ZC Vtec all the time. Just let him know that your interested in one and he will be able to tell you when he is going to have them in stock.
There like $50 more than a D15b, **** I would pay $50 dollars for a bit of more displacement and an engine that is compatible with a D16Z6 any day.
Old Sep 20, 2005 | 07:37 PM
how did you deal with the O2 sensor? I hear the zc has only two wires and the usdm uses four wires
Old Sep 20, 2005 | 08:09 PM
I used the ecu the D15B comes with (P08) which is a single wire O2 sensor. Convenient for myself because CX also come with a single wire O2 sensor. Im currently running the CX exhaust manifold with the catilytic converter up front with the ZC Vtec.
Old Sep 20, 2005 | 08:22 PM
sounds good, i might go this route after i'm done with my b7..thanks!
Old Sep 20, 2005 | 08:51 PM
93SiHB's Avatar
Yah i stated the single cam ZC Vtec but i guess the guy who replied got confused. Anyway i have one more question; i was told these have one less sensor is that correct or is that the DOCh he was talking about. Can i pass smog with this i currently have the D!6z6 but the head is seriously warped and gasket blown. It burns the oil and water in one trip so ya I need to get a new motor thanks for clearing that up for me. Looks like im definetly going for the ZC Motormounts are all the Same Right?
Old Sep 20, 2005 | 09:19 PM
Yes motor mounts are all the same, to be honest I am not sure if whether you could pass CA emissions with a ZC Vtec. I've heard of people that have passed emissions by using their Z6 intake+exhaust manifold along with their P28 ECU.
ryan_long_01
Feb 7, 2006 06:05 AM
CUPRA_ROY
13
Jul 29, 2005 10:41 AM
gutted-dx
Jul 10, 2004 10:01 AM
EJ1_519
Mar 20, 2004 09:34 AM
94_civic_guy
13
Jul 16, 2003 09:43 AM
