My new civic porject.
Old Sep 20, 2005 | 06:35 AM
CBURKE's Avatar
Default My new civic project.
Here she is I'll post more as I go along. This will be a d16 Si turbo, that I will be building from ground up. I want to run as much boost as I can so I will do this right the first time. Here are some pics.
A little head work. It's not the greatest, I did it with a dermal.
wheel studs.
no motor.
that's all for now
Does anyone know what the deal is with using the O2 housing from the mitsu?
Old Sep 20, 2005 | 08:02 AM
turbotommy's Avatar
Default Re: My new civic project. (CBURKE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">Here she is I'll post more as I go along. This will be a d16 Si turbo, that I will be building from ground up. I want to run as much boost as I can so I will do this right the first time . Here are some pics.
A little head work. It's not the greatest, I did it with a dremel .
ummm...i dont beleive this is the "right" way. i dont know how you can do headwork without a flow bench?
Old Sep 20, 2005 | 08:35 AM
WVTURBOCRX's Avatar
Default Re: My new civic project. (turbotommy)
Correct, with out the flow bench you will not have an even flow. One port may be a 3% gain and another may be at 6% gain, so you will have uneven flow witch is not good.
Old Sep 20, 2005 | 09:29 AM
CBURKE's Avatar
Well all I really did was port mach and polish a little
Adankid
Sep 18, 2008 02:05 PM
chuniepatuni
Honda Civic (2006 - 2015)
33
May 2, 2007 09:27 PM
aemracerex
Feb 23, 2006 09:20 PM
CBURKE
Sep 27, 2005 11:50 AM
b18cya
Feb 25, 2003 08:29 AM
