CTR cams on High comp
Old Sep 20, 2005 | 12:24 AM
Cherchez La Ghost's Avatar
Default CTR cams on High comp
Yesterday i found out my motor is burning oil. When I went for my normal oil change almost nothing was in there (1/2 quart). My vtec still kicked hard but i was noticing the engine sounded alot "rougher". I wont kno how much damage i've done until i take off the head but its running fine after i changed the oil. I dont think the rings were sealed properly after the rebuild or could it be the AZ heat? Anyway...
I'd rather just do a light ls/build than re-hone my b16 if my sleeves are damaged. I would like to gain some more hp along with the TQ but i really cant spend more than 1k. If i ran CTR pistons in the ls block i would get somewhere around 12:8:1 comp correct? The reason I'd be using such a high comp is because one of these days i'll buy some skunk2 pro2's...I'm just waiting to see how they perform.
I want to throw in some CTR cams but im not sure if my stock b16 springs/retainers can handle the extra lift. Also how do you think the cams will run on the high comp?
Old Sep 20, 2005 | 07:14 AM
Jason.H.'s Avatar
Default Re: CTR cams on High comp (Lekz)
i dont think there will even be a noticable diff in power gains with the ctr's.
Old Sep 20, 2005 | 10:46 AM
Ekay Jay's Avatar
Yes ur b16 valvetrain can handle ITR/CTR cams. And they should be fine with that cp.
em1_fox
Aug 13, 2009 10:08 AM
DA3
Apr 7, 2009 11:37 AM
norcalbayboy
Aug 17, 2006 08:04 AM
RedEj8
Jun 1, 2005 06:40 PM
