Need some advice for a friend....Break-in with DSM 450cc and stock ecu?
Old Sep 20, 2005 | 12:14 AM
OMG B16's Avatar
Default Need some advice for a friend....Break-in with DSM 450cc and stock ecu?
Alright well my friend just built a ls-vtec, i helped him and got him most of the info he needed and he had a engine builder build it for him, so now its almost time to put it in, and he plans on using DSM 450c injectors and just turning the pressure down with a Fuel Pressure Regulator to break-in the motor. After break-in it will be turboed. Will this work? i dont think it will personally, i believe it will wash the cyl walls, i dont know too much about fuel pressure or anything, but using the 450cc injectors how will the fuel be cut?
Gimme some advice to give him, I told him to just get some stock injectors and break it in that way, but he insists on using the DSM injectors.
Old Sep 20, 2005 | 03:51 PM
OMG B16's Avatar
Someone tell me what to tell him, lol....
Old Sep 20, 2005 | 07:11 PM
IN VTEC's Avatar
Default Re: Need some advice for a friend....Break-in with DSM 450cc and stock ecu? (Sick00SiCoupe)
It'll barely start or idle, and driving it won't be much fun either. It's just asking for headaches, and turning the pressure down could make the problem worse.
Old Sep 20, 2005 | 07:15 PM
IMALLSLO's Avatar
Default Re: Need some advice for a friend....Break-in with DSM 450cc and stock ecu? (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">It'll barely start or idle, and driving it won't be much fun either. It's just asking for headaches, and turning the pressure down could make the problem worse.</TD></TR></TABLE>
What he said. Just wait till he turbos it to add the injectors. Even 450s may be a bit much on a stock block with low boost and no fuel management.
Old Sep 20, 2005 | 07:38 PM
OMG B16's Avatar
When he goes turbo, he is going to get a P28 with crome, and i finally convinced him to get the stock injectors....
Old Sep 20, 2005 | 08:44 PM
EnzoSpeed's Avatar
Default Re: (Sick00SiCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sick00SiCoupe &raquo;</TD></TR><TR><TD CLASS="quote">When he goes turbo, he is going to get a P28 with crome, and i finally convinced him to get the stock injectors....</TD></TR></TABLE>
Good. When you start a new motor, you need the AFR's to be PERFECT as soon as possible. I wouldn't dream of starting a new motor with anything but stock injectors.
2ndchirp
Nov 4, 2008 09:57 AM
1SickHb
Dec 9, 2005 08:13 AM
grover
Jun 24, 2005 07:11 PM
boonacka
Aug 16, 2004 09:30 AM
liquidxEG
Jul 18, 2004 07:20 AM
