How good is a OEM JDM Type R header+CAT combo - Comparisons?
Old Sep 19, 2005 | 10:16 PM
schumi's Avatar
Default How good is a OEM JDM Type R header+CAT combo - Comparisons?
Searched but couldn't find any comparisons.....
How good is this JDM combination when compared with a typical 4-1 DC header+CAT combination?
What are the performance gains? any idea on the decent price for this?
Thanks
Old Sep 19, 2005 | 10:18 PM
Chewie's Avatar
Default Re: How good is a OEM JDM Type R header+CAT combo - Comparisons? (schumi)
JDM is 2.5" collect and the DC is 2.25". you want you whole exhaust system to the the same inner diameter size for better airflow. Unless you have internals and tuning done, 2.5" is really not needed.
Old Sep 19, 2005 | 10:31 PM
schumi's Avatar
Default Re: How good is a OEM JDM Type R header+CAT combo - Comparisons? (Chewie)
Yes, I also have an after marker CAT back system with a 2.5" mandrel bent piping
Old Sep 20, 2005 | 08:08 AM
schumi's Avatar
Any inputs? Issues of bottoming out with OEM JDM Type-R headers?
Modified by schumi at 8:47 PM 9/20/2005
Old Sep 20, 2005 | 11:55 AM
2G0S0R1's Avatar
New User
I am running the JDM 4-1 and I think its the best header for the price.
It is high quality from Honda, and uses full penetration welds for strength. It seemed to make good top end on my GSR, but alot of headers will do that.
It doesnt hang that low... Not anywhere near as low as the DC JDM 4-1 (I have both), and there is a really nice skidplate available that bolts on.
The actual Inside diameter is closer to 2.36" because of the double walled construction... most exhausts (like your "2.5" CAT back) are also only 2.36" or 2.25" Internal diameter so it will mate well.
I recommend getting a 2.5" cat (I personally have trashed 2 carsounds) that is of a spun, or round design. Best prices I have found are here: http://www.rpmoutlet.com/powercat.htm
Try it out, Im liking mine... and it didnt break the bank.
Old Sep 20, 2005 | 12:48 PM
schumi's Avatar
Default Re: How good is a OEM JDM Type R header+CAT combo - Comparisons? (2G0S0R1)
The set up has the oem JDM Type R CAT also.....How about the JDM CAT compared to that of aftermarket ones?
Old Sep 20, 2005 | 12:49 PM
2G0S0R1's Avatar
New User
Good enough... and will look much more legal. A test pipe doesnt free up that much power anyways, unless you are boosted.
Old Sep 20, 2005 | 04:01 PM
schumi's Avatar
How much gains can be expected with a OEM JDM Type R header + OEM JDM Type R CAT mated to a 2.5" CAT back exhaust system with a Magnaflow muffler?
Old Sep 20, 2005 | 08:55 PM
schumi's Avatar
Ok. It not the Type R header but a stock GSR header (looks like flange was welded to GSR CAT)
So, How much gains can be expected with a OEM JDM Type R header + OEM USDM GSR CAT mated to a 2.5" CAT back exhaust system with a Magnaflow muffler?
Old Sep 21, 2005 | 06:05 AM
maggsgsr's Avatar
The JDM DC 4-1 produces a couple more ponies but hangs lower
Old Sep 21, 2005 | 09:52 AM
2G0S0R1's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schumi &raquo;</TD></TR><TR><TD CLASS="quote">...OEM USDM GSR CAT...</TD></TR></TABLE>
Not much buddy, I mean you are getting more flow... then stopping it... then trying to get it back.
You might get a couple horses at best from the header scavenging effects, thats it.
like I said... get a cat for $70... the flanges from Kteller for $40... and then welded for ~$30... then you will get more power.
Old Oct 3, 2005 | 08:06 PM
Nataku's Avatar
is it worth the extra money for this set up as aposed to a megan (for example) GSR header with highflow cat? is it worth it to go JDM ITR?
ITR Factor
Jan 6, 2004 08:01 PM
AllMotorITR
Nov 14, 2003 12:29 AM
(__________)
Jun 30, 2002 05:17 PM
Toda Party
Oct 10, 2001 11:54 PM
Import Horizon.com
Jul 11, 2001 01:26 PM
