Can a Rsx motor (base model) take the type S tranny?
Yes, but I think you need a Type-S clutch and flywheel or aftermarket Type-S application.
Search for klutchrsx on http://www.clubrsx.com He did that swap before.
I haven't looked at a base model block to see what the oilpan looks like, but the Type S tranny bolts directly to the oilpan. In changing to the Type S transmission you may have to use the Type S oilpan if it is indeed different.
might want to change flywheel on this one along with some aftermarket clutch components. as far as I know they do interchange.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chunty Butt Kevin »</TD></TR><TR><TD CLASS="quote">whats the reason for this swap</TD></TR></TABLE>
closer gearing would be my guess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Captin Bodussy »</TD></TR><TR><TD CLASS="quote">closer gearing would be my guess.</TD></TR></TABLE>
Yuppers, especially useful if you've reprogrammed/reflashed the ECU to get a higher redline.
Or if you do a head swap, putting an A2 head on an A3 block.
My ideal tranny: '05+ RSX-S 1-5 & FD, TSX 6th, LSD (in short, the '06 Si's tranny)
litterbox
15
Aug 5, 2005 03:04 AM
