alarm problem (remote engine start)
Old Sep 19, 2005 | 07:55 PM
JCracer723's Avatar
Default alarm problem (remote engine start)
i just got an alarm (X plore xr-7025) when i hook up the engine start and press the button on the alarm pager the starter just keep going and going. what do you think its the problem??.. the guy that installed said it was the alarm brain..
BTW this isnt in a honda its on a jeep cherokee
this is the alarm
http://store.teptronics.com/xr7025.html
Modified by JCracer723 at 5:08 AM 9/20/2005
Old Sep 20, 2005 | 07:26 AM
B18C_EJ8's Avatar
Default Re: alarm problem (JCracer723)
The brain doesn't know that the car is started and it's hanging the starter... Relearn the tach signal, or if you didn't run the tach wire, run it and program it.
Old Sep 20, 2005 | 12:07 PM
fcm's Avatar
fcm
Old Fart
Default Re: alarm problem (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">The brain doesn't know that the car is started and it's hanging the starter... Relearn the tach signal, or if you didn't run the tach wire, run it and program it.
</TD></TR></TABLE>Ditto that. 94
Old Sep 20, 2005 | 01:31 PM
JCracer723's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">The brain doesn't know that the car is started and it's hanging the starter... Relearn the tach signal, or if you didn't run the tach wire, run it and program it. </TD></TR></TABLE>
and i find that tach wire runnin from the ecu to the cluster?
Old Sep 20, 2005 | 03:06 PM
fcm's Avatar
fcm
Old Fart
YMM of car? 94
Old Sep 20, 2005 | 03:54 PM
JCracer723's Avatar
Default Re: alarm problem (fcm)
95 jeep grand cherokee
Old Sep 20, 2005 | 06:15 PM
B18C_EJ8's Avatar
I think on those jeeps you need to go to the dizzy or an injector for tach...
Old Sep 20, 2005 | 08:09 PM
vicn77's Avatar
Default Re: (B18C_EJ8)
injector is easier i believe
Old Sep 21, 2005 | 04:05 AM
B18C_EJ8's Avatar
Can also get true tach signal at the PCM, which is under the hood, high on the passenger side firewall. It's gray/blue.
However, if you use an injector wire, go to any injector, but tap the wire that's not common. Meaning, on all injectors, there will be 2 wires, one of which will be the same on every one. Use the uncommon one and you'll be fine.
Old Sep 21, 2005 | 08:28 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">Can also get true tach signal at the PCM, which is under the hood, high on the passenger side firewall. It's gray/blue.
However, if you use an injector wire, go to any injector, but tap the wire that's not common. Meaning, on all injectors, there will be 2 wires, one of which will be the same on every one. Use the uncommon one and you'll be fine.</TD></TR></TABLE> Ditto that. 94
Old Sep 21, 2005 | 03:16 PM
JCracer723's Avatar
Default Re: (fcm)
thanks for all the help..
now would u guys be so kind and help me understand how to connect the power locks.. i heard i need some sort of resistors? or relays?
Old Sep 21, 2005 | 04:18 PM
fcm's Avatar
fcm
Old Fart
Default Re: (JCracer723)
Well according to http://www.bulldogsecurity.com and http://www.the12volt.com they are Type "A" [positive trigger] lock is orange/purple and unlock is pink/purple and they can be found at the black plug behind driver's kick panel, if your alarm/remote start does not have pos. (+) door lock outputs you will have to install relays, like this http://www.the12volt.com/relays/page1.asp to change the neg. output to a pos. output 94
mattmaine1991
Audio / Security / Video
Oct 21, 2016 12:36 PM
nine00
Nov 4, 2009 09:02 AM
Xxcivic99xX
Nov 29, 2008 06:51 AM
ezol
Jan 5, 2007 04:30 AM
NINJA
Nov 21, 2003 09:57 AM
