type r lsd in cable ls tranny? Anyone know about this?
Old Sep 19, 2005 | 05:38 PM
rorik's Avatar
Default type r lsd in cable ls tranny? Anyone know about this?
I have an old ls cable tranny with an exploded diff. When I say exploded, I mean it put a hole in the case..Anyway, after I weld the stupid case back together, I want to make this tranny better than it was before. I can't afford a 'queef' though, so I was wondering if I could install a factory type r unit. I looked up the application numbers on the quaife site, and the gsr/type r has a different part number than the b16/ls application. Can anyone give me a definitive answer on this? I know you guys know this..
Old Sep 19, 2005 | 05:51 PM
DaveF's Avatar
Default Re: type r lsd in cable ls tranny? Anyone know about this? (rorik)
maybe you can weld your blown up diff back together?
Old Sep 19, 2005 | 05:55 PM
HondaCivicSiR1's Avatar
Default Re: type r lsd in cable ls tranny? Anyone know about this? (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rorik &raquo;</TD></TR><TR><TD CLASS="quote">I have an old ls cable tranny with an exploded diff. When I say exploded, I mean it put a hole in the case..Anyway, after I weld the stupid case back together, I want to make this tranny better than it was before. I can't afford a 'queef' though, so I was wondering if I could install a factory type r unit. I looked up the application numbers on the quaife site, and the gsr/type r has a different part number than the b16/ls application. Can anyone give me a definitive answer on this? I know you guys know this..</TD></TR></TABLE> queef quaife same thing.lol
Old Sep 19, 2005 | 06:42 PM
Aggressive Racing's Avatar
Default Re: type r lsd in cable ls tranny? Anyone know about this? (HondaCivicSiR1)
HAHAHA He said Queef. lol
Old Sep 19, 2005 | 07:32 PM
sicsixone's Avatar
Default Re: type r lsd in cable ls tranny? Anyone know about this? (aggressivemotorsports)
yes you can do it,but you will have to remove a small amount of the webbing in the trans case.
Old Sep 21, 2005 | 12:34 AM
rorik's Avatar
Default Re: type r lsd in cable ls tranny? Anyone know about this? (jonsswapshop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonsswapshop &raquo;</TD></TR><TR><TD CLASS="quote">yes you can do it,but you will have to remove a small amount of the webbing in the trans case.</TD></TR></TABLE>
Are you certain of this?
Removing webbing won't be a problem, the old diff did a lot of that for me..
Old Sep 21, 2005 | 04:04 AM
Zubaltec's Avatar
Read this post.
https://honda-tech.com/zerothread?id=1369903
I know you have a cable trans, blah, blah. The diff. might fit, but the LS ring gear isn't going to fit the Type R LSD.
John
jdm.fanatic
Dec 2, 2007 04:38 AM
speedworks2000
Sep 2, 2005 10:10 AM
hotimportcrx
Jun 28, 2005 08:58 PM
4potnick
Jul 27, 2003 03:47 PM
