My compression on the D16z6
Old Sep 19, 2005 | 03:30 PM
BloodPressure's Avatar
Default My compression on the D16z6
Cylinder 1 = 170, Cylinder 2 = 170, Cylinder 3 = 180, Cylinder 4 = 180. 95 del sol with 185,000 miles. This about right?
thanks,
justin
Old Sep 19, 2005 | 03:34 PM
unknown0001's Avatar
Default Re: My compression on the D16z6 (BloodPressure)
yes and it seems pretty good too
Old Sep 19, 2005 | 03:44 PM
Thanks a bunch, now it's time for some power. Any suggestions? All i wanna do is be able to dois merge into traffic with the A/C on and not almost be killed by a 79 cadillac diesel
Old Sep 19, 2005 | 04:20 PM
AbitAvenger's Avatar
heh, my name is justin and i have a d16z6 with similar compression and miles
the only real way to get good power from a D series motor is to go turbo
Old Sep 19, 2005 | 04:24 PM
nota-eg's Avatar
Default Re: (AbitAvenger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger &raquo;</TD></TR><TR><TD CLASS="quote">heh, my name is justin and i have a d16z6 with similar compression and miles
the only real way to get good power from a D series motor is to go turbo</TD></TR></TABLE>
If all you want is a little merging power a small TD04 is PERFECT. I finally got around to installing everything and got all of the kinks worked out.
It's perfect. Hits about 5psi at 2500 and at 3300 you're at 8psi. Great for merging.
Old Sep 19, 2005 | 05:02 PM
Default Re: (nota-eg)
I want to keep it N/A, possibly pistons from a D16a1. I have been interested in doing this for a while, but would like to see some dyno's first. BTW does anyone know where I could see these #s?
Thanks,
Justin
Old Sep 19, 2005 | 05:10 PM
1995Ex_Sedan's Avatar
Honestly, Pistons aren't going to help you that much. You'll need to spend a wad of money to get power out of your NA d16.
Old Sep 19, 2005 | 05:15 PM
Default Re: (1995Ex_Sedan)
That's a bummer, but i'm glad someone told me. I figured the increased CR would do the trick....like maybe 15 20hp would be nice. I'm gonna disconnect my PS, and maybe the A\C in the winter. It should help a bit.
Thanks,
Justin
Old Sep 19, 2005 | 05:22 PM
nota-eg's Avatar
Default Re: (BloodPressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BloodPressure &raquo;</TD></TR><TR><TD CLASS="quote">That's a bummer, but i'm glad someone told me. I figured the increased CR would do the trick....like maybe 15 20hp would be nice. I'm gonna disconnect my PS, and maybe the A\C in the winter. It should help a bit.
Thanks,
Justin</TD></TR></TABLE>
That'll free up some power. You could also look into some more aggressive cams. Maybe a CAI and full exhaust w/ headers back.
thomabra001
Dec 11, 2010 12:16 PM
lalocivic
Jan 4, 2010 07:27 PM
EG6 Love
Feb 16, 2008 03:35 PM
wfocrx
Jun 23, 2006 08:09 PM
xXx Justin xXx
May 15, 2003 09:42 PM
