leak down test kit
Old Sep 19, 2005 | 02:10 PM
( o )( o )'s Avatar
Default leak down test kit
I just read c-speedracing's how-to on a leak down test.
my new build's initial compression test was a little disappointing. i will do the compression again for the next few days but if numbers don't improve, then perhaps I have bad valves.
where can i buy my own leak down test kit? i searched sears and several auto stores with no luck. please help!
thanks
Old Sep 19, 2005 | 05:15 PM
cleanEG's Avatar
Default Re: leak down test kit (( o )( o ))
Snap-ON sells them....thats where I picked up mine. I just called some local repair shops for the local snap-on guy's phone number.
Old Sep 19, 2005 | 05:42 PM
( o )( o )'s Avatar
Default Re: leak down test kit (cleanEG)
damn - i just went to snap-on.com and found a cylinder leakage tester for $299!!!!
c-speedracing says they can be had for 60ish. anywehre else??
Old Sep 19, 2005 | 07:13 PM
( o )( o )'s Avatar
well i may not need the leakage tester just yet. i put 50 miles on it saturday and checked compression sunday morning. all cylinders were 190-200ish. today i checked after work before heading home and they were all around 220.
i'm going to put some more miles on her and check compression each day after work. as soon as the readings level off, the rings should be seated.
Old Sep 21, 2005 | 04:20 AM
quickcarl's Avatar
Definetly put some miles on it, then test it.
dazcivic
Oct 25, 2011 02:09 PM
niterider96cord
Jun 22, 2010 07:46 PM
humboldt_skim
May 31, 2008 08:18 AM
ST4TUS
Jul 16, 2006 07:38 PM
Propulsion
Jun 5, 2002 11:48 PM
