does timing tension pully bolt auto tightn the pully or do i have to manual tightn pully by hand? pi
Old Sep 19, 2005 | 10:22 AM
redpeppers's Avatar
Default does timing tension pully bolt auto tightn the pully or do i have to manual tightn pully by hand? pi
i was wondering ...i am trying to avoid taking the manin crank pully off.....i loosened the timing tension pully bolt without taking the timing cover off...i readjusted the timing....i was wondering if i have to manual tightn the pully by hand or when i tightn the pully bolt will it auto tightn.......i have a helms service manual but it is not too clear.....check out pic below....basicly i need to know how to tightn the pully is what to boils down too
Old Sep 19, 2005 | 10:32 AM
BlackLudeSi's Avatar
Default Re: does timing tension pully bolt auto tightn the pully or do i have to manual tightn pully by hand
If its a newer belt you shouldn't have to put to much tension on the belt, but yes you want to make sure its holding the belt tight or its not doing any good. Hold it tight while you tighten down the tension bolt
musikpal
Aug 28, 2009 01:41 PM
danewickenhauser
Jul 25, 2009 04:38 PM
eg_h22
Mar 16, 2009 12:58 PM
nemesis25
Jan 2, 2008 04:48 PM
tmrtwo
Feb 2, 2007 04:43 PM
