lock just springs back....
ok look i took on my door panal but i get seem to figure out y my door lock spring back.so i cant lock my car.....anyone know what im talking about ???
If its on a G2 integra you have to pull the door handle before it will let you lock it, unless you use the key. There might be something in the way of the rods the lock/unlock your door
pull the panel off, its just a few screws and some clips, on the back for the door lock there are two metal rods the lock and unlock the door. They are connected by weak plastic clips it is common for them to fall off or break. Thats what I would check out
