Turn Signal Issues
Old Sep 19, 2005 | 08:50 AM
IMPACT's Avatar
Default Turn Signal Issues
Hey guys, last night on my way home i noticed that my right bumper signal was going apeshit. I pulled up infront of the garage and put on my left signal. It wasnt working. So the genius that I am. i proceeded to change the bulb! ****, that did sweet **** all! For some reason even after changing the bulb, it did nothing. Would the "maintainace required" light come on for that?
Thanks in advance
Old Sep 19, 2005 | 08:52 AM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Re: Turn Signal Issues (IMPACT)
No the maintenance required wouldn't go on because it is a timed device depending on your mileage of car. I would guess a connection somewhere. Check the connections of your front blinker.
Old Sep 19, 2005 | 08:57 AM
IMPACT's Avatar
Hmm....interesting. The maintainance light is another topic. I'm running Hondata, why would that light even come on then. I have 183,000km on the odometer. But the motor is somewhere around 90,000km. Well im gonna check the connections. Thanks
Old Sep 19, 2005 | 08:58 AM
BlackLudeSi's Avatar
Default Re: Turn Signal Issues (ahrpr)
when they start blinking fast like that and one does not work its usually a bad bulb/connection its check the connections and grounds for a rusty one.
Old Sep 19, 2005 | 09:08 AM
IMPACT's Avatar
Ah hah! I see that makes sense. Thanks for the info, that makes me feel a bit better. I wonder why it just happened. Although we had a really bad rainstorm on Saturday. Well then.
Does anyone know how to clear the "maintainance required" light? Its really getting on my nerves.
Thanks again
Old Sep 19, 2005 | 09:18 AM
its usually a lettle key slot in the cluster ( at least on civics tegs might be different) you just put the stock key in it to turn it off
Old Sep 19, 2005 | 09:33 AM
Default Re: Turn Signal Issues (BlackLudeSi)
on an integra there is a box under the dash on the driver side on the right side of the wheel and there is a button, feel around and youll find it and push it and hold until the light turns off.
Old Sep 19, 2005 | 04:12 PM
=RACEbred='s Avatar
hey dude sounds funny but check your fusez
those little ******** make hondas do weird things if one goes out
Old Sep 20, 2005 | 10:41 AM
vinai's Avatar
here is the link
http://photobucket.com/albums/...1.jpg
the arrow points to the location and next pic show what it looks like
http://photobucket.com/albums/...2.jpg
Old Sep 20, 2005 | 10:58 AM
Chewie's Avatar
Default Re: Turn Signal Issues (vinai)
that pic was so big, it hurt my eyes. Same as everyone said, check connections.
Old Sep 20, 2005 | 01:53 PM
vinai's Avatar
Default Re: Turn Signal Issues (Chewie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chewie &raquo;</TD></TR><TR><TD CLASS="quote">that pic was so big, it hurt my eyes. Same as everyone said, check connections.</TD></TR></TABLE>
I was going to use the other link except that it was super small so I figured I should use the bigger one
tchubs2K
Mar 27, 2017 01:01 PM
98dxkoupe
Lighting
15
Oct 12, 2015 05:33 AM
Metal Typhoon
Oct 17, 2006 05:14 PM
niteboyzzz
Oct 4, 2002 11:24 PM
