rear dis swap on non ABS EK - which prop valve?
Old Sep 19, 2005 | 01:38 AM
Bullitt's Avatar
Default rear dis swap on non ABS EK - which prop valve?
Since my drums have gone bad in the rear. I´m going to swap rear disc brakes on my EK Hatchback. I have a EJ9, basically the same like the USDM "DX" model. I have no ABS. So there are six brake lines going into my stock proportioning valve.
Which prop valve do I have to use with rear discs? I know it must be a 4040, but will a valve from a 99 Si work, because the car has ABS from Factory?
Help me out, this is the last thing that is missing
Old Sep 19, 2005 | 11:34 AM
IHateJDM's Avatar
Default Re: rear dis swap on non ABS EK - which prop valve? (Bullitt)
you can use any 40/40 prop valve.
Old Sep 19, 2005 | 02:31 PM
joe_bocc's Avatar
You need the prop valve out of a 99-00 Si w/o ABS. I know they exist because I have one. As far as I know its the only prop valve that has the proper orientation for your hard lines. to tell the difference, the ABS prop valves only have 4 port where as the non-ABS have 6 ports.
Old Sep 19, 2005 | 09:36 PM
ej0513's Avatar
EK DX and EK Si are the same prop valve.. you switch nothing..
Old Sep 19, 2005 | 11:38 PM
Bullitt's Avatar
Default Re: rear dis swap on non ABS EK - which prop valve? (joe_bocc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joe_bocc &raquo;</TD></TR><TR><TD CLASS="quote">You need the prop valve out of a 99-00 Si w/o ABS. I know they exist because I have one. As far as I know its the only prop valve that has the proper orientation for your hard lines. to tell the difference, the ABS prop valves only have 4 port where as the non-ABS have 6 ports.</TD></TR></TABLE>
were did you get yours?
Do you have a part number so I can check with my local honda dealership?
Old Sep 20, 2005 | 04:25 AM
v4lu3s's Avatar
RTFM
you dont switch a thing.
as ej0513 said they are all teh same part number.
if you dotn beleive me go look at http://www.slhondaparts.com and compare part numbers for all 96-00 honda civics.
46210-S04-902 is the part number for the 96-00 non abs prop valve.
99 civic si prop valve:
http://www.slhondaparts.com/br...4-902
99 civic cx prop valve:
Old Sep 20, 2005 | 03:40 PM
dynamo's Avatar
Default Re: (v4lu3s)
v4lu3s is 100% correct. I'm doing my second rear disc conversion this week, and this time around I know that I don't need to swap the prop valve. You definitely want to upgrade your MC to 7/8 (stock 99-00 Si MC size), and you don't even need to switch the booster because the part numbers for the booster are the same for all 99-00 civics. Switching your stock 13/16 to 7/8 master cylinder should be a direct bolt in, so no need to worry about bending and flaring custom brake lines.
Old Sep 20, 2005 | 09:48 PM
akteamster's Avatar
Default Re: (ej0513)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej0513 &raquo;</TD></TR><TR><TD CLASS="quote">EK DX and EK Si are the same prop valve.. you switch nothing..</TD></TR></TABLE>
im doing a full gsr brake swap on my 96 dx too
Old Sep 24, 2005 | 10:24 AM
gotboostedvr6's Avatar
Default Re: (dynamo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynamo &raquo;</TD></TR><TR><TD CLASS="quote">v4lu3s is 100% correct. I'm doing my second rear disc conversion this week, and this time around I know that I don't need to swap the prop valve. You definitely want to upgrade your MC to 7/8 (stock 99-00 Si MC size), and you don't even need to switch the booster because the part numbers for the booster are the same for all 99-00 civics. Switching your stock 13/16 to 7/8 master cylinder should be a direct bolt in, so no need to worry about bending and flaring custom brake lines. </TD></TR></TABLE>
is the diameter of the booster bigger on the 99-00 si ?
Old Sep 24, 2005 | 11:30 AM
ej0513's Avatar
Si MC is either 7/8ths or 15/16ths.. its wierd.. some people claim to have one or the other, so i guess they are not the same.. but your best bet for a complete bolt in is to use 98+ Integra MC and BB.. its 1 inch, but i myself used a DC5 15/16th MC and BB and it worked great.. it just needed a little bending of the lines.
Old Sep 26, 2005 | 06:02 AM
Bullitt's Avatar
I´m still confused. I got the part number from my stock brake valve, its 46210-S04-801
The other parts listed above have the ending 902.
Does anybody have infos about this part? Can I use it, or is it the wrong thing?
Old Sep 26, 2005 | 07:54 PM
v4lu3s's Avatar
RTFM
the part number i listed is for the 99-00 civic si, as well as all 96-00 hatchbacks, the sedans and coupes may have diff part numbes.
Old Sep 26, 2005 | 08:12 PM
ej0513's Avatar
all 96-00 hatchback, coupes and sedans have the same proportioning valve.. sooo.. no need to change anything when doing a drum to disk conversion.
Old Sep 27, 2005 | 08:02 PM
v4lu3s's Avatar
RTFM
the coupes and sedans Do have a diff part number indicating there are different revisions out there...
Old Sep 27, 2005 | 08:13 PM
ej0513's Avatar
^oh.. my bad.. i was going off the fact that my 98 hatch and 99-00 Si coupes had the same.. i just checked slhonda.com and the part numbers are different.. as for the actual difference.. i dont know.. and BTW when i checked the part numbers it was for DX models.
Old Sep 27, 2005 | 08:14 PM
ej0513's Avatar
but back to the original posters question, which has nothing to do with sedans.. he does not need to change the valve.. [/thread]
nitewolf
Apr 3, 2009 11:26 AM
sony224422
Feb 13, 2008 01:31 PM
nikolai.
Jan 12, 2007 11:08 PM
FuNkDrSpOt
Oct 9, 2006 07:31 PM
Simple
Apr 22, 2003 08:42 PM
