Water leak into the drivers side
Hi all,
I have a '91 Honda Integra LS.
When I wash my car, or it rains a lot, water drips into the drivers side where the pedals are. I'm sure it's not good for the car, and could be dangerous. Not to mention the annoyance factor and my car smelling for the next coupld of days.
I was wondering if anyone else has had a similar problem, or has any idea of a fix.
Thanks in advance for any help.
Is it only when it rains or when you wash it? I had that same problem on my car, but it was the ac drain tube. It was clogged so all the condensation from my ac would flood my car. You might want to check that. Small tube hangs down on the right side, next to oil pan.
super comon problem but usually happens on the passenger side I've heard it can happen to the driver side to go to this link http://www.g2ic.com/index2.php its under teg tips and there is one on team integra but I dunno were
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pny1981 »</TD></TR><TR><TD CLASS="quote">Is it only when it rains or when you wash it? I had that same problem on my car, but it was the ac drain tube. It was clogged so all the condensation from my ac would flood my car. You might want to check that. Small tube hangs down on the right side, next to oil pan.</TD></TR></TABLE>
same here...
same here...
supertouch
Honda Civic (2001 - 2005)
Jul 28, 2007 04:38 AM
Guaguita
Oct 2, 2006 07:08 AM
