need help please!!!!
Old Sep 18, 2005 | 04:58 PM
toooslow's Avatar
Default need help please!!!!
Today while i was driving, approx. (50mph just cruising) and all of a sudden my car starts to sound like a wrx. The exhaust tone was very lopey and there was lots of hesitation. I pull over and it sounded like an injector was unplugged so i go to unplug the injectors 1 by one to see if engine idle lowers and the first one i pulled did nothing to the idle. I tried the rest one by one and they all made idle lower. I had the car towed to my house and i replaced the faulty injector with new one. i started up the car and the Idle is perfect again I can rev it and its all fine. Now the car blows tons of white smoke. At idle its not noticeable but when i push the throttle it smokes alot. The first thing i thought was blown headgasket. I checked oil, color is still fine, no milky effect. Doesnt look like i lost coolant after checking it. What would effects could that faulty injector have caused? thanks. Engine is a b20vtec just build, before this incodent, there was no smoke at all.
Old Sep 18, 2005 | 06:42 PM
mmuller's Avatar
Mad Scientist
Default Re: need help please!!!! (toooslow)
have you checked spark plugs to see wich is the causing cylinder/s?
Old Sep 19, 2005 | 08:56 PM
sicsixone's Avatar
Default Re: need help please!!!! (mmuller)
also check your oil level make sure it is not over filled
themorphious
Engine Management and Tuning
Mar 24, 2012 08:46 AM
gnxpro24
Jun 6, 2011 01:28 PM
jdmwarrior
Sep 27, 2009 12:59 AM
BlueSi2k
Dec 22, 2003 11:01 AM
EMod Civic
Oct 28, 2001 05:23 PM
